Dear @Paul Smith,
When you have Unestimated item scheduling set to Base on target dates, an unestimated issue should be shown if it is assigned to a sprint, a release, or has target dates itself.
Try turning off Sprints in the Schedule settings (to right of the Calculate button) or have a look at the Target schedule.
If this is not what you are looking for, please provide screenshots so we can better understand the problem.
I hope this helps!
The Portfolio team
Hi thanks for the response, and apologies maybe I was not as clear as I could have been.
My issue is purely with the end date of the epic in portfolio view. In the situation I described where there is no estimated work in the epic, however there are fixversions attached with dates against them, I would expect the epic duration to extend to the latest date of the fixversion attached to the epic.
Can you advise why this behaviour would not occur?
