Portfolio Completed Issues Days not saving
larry joseph
In the Improved Interface we are trying to get it to show some completed issues. I found on the Configuration > Issue Sources screen a field that it lets you choose how long any completed issue will show on the plan. Problem is it doesn't retain my changes to the value. It seems set at 30 days and you can click the up/down arrow in the field to change it, but if you leave the screen and come back, it's reset back to 30.  Is this a bug, permission issue, Admin issue, user error....?
See https://confluence.atlassian.com/jiraportfolioserver/issue-sources-967895168.html
See attached screen shot
Mark Davies
October 11, 2020
Hi @larry
This does sound strange. When you change the value in the textfield from 30 days, make sure you click outside the textfield before leaving the page. Otherwise it might not be updating this change.
Cheers
Mark
larry joseph
Thanks for suggestion.  I got it to work, but not by clicking off.  I found that if I use up/down arrows to change value I have to click into the field before the change is recognized.  I also had some odd behavior previously trying to click into and type the value.  So there is something odd about how the field works (wonder if browser issue?), but I got it to take the new values.  Thanks.
Like Mark Davies likes this
Joseph Chung Yin
@larry joseph - Glad it worked for you.  Try it by entering the value without using the up/down arrows, then simply click on "back to plan".  The changed value should also be retained as I described in my previous answer.
The odd part is that in our env, we don't see the up/down arrow.  BTW we are using Chrome to access Jira/AR.
Best, Joseph
Joseph Chung Yin
@larry joseph - We are using Jira DC 8.9.1 with AR 3.29.1 (On Prems).  In our env, we don't have the up/down arrows to change the days.  We enter the value to adjust the default 30 days setup.  All we have to do is to go back to the plan "Back to Plan" and the value is saved.
The only time where change will revert back to the default setting if we set it to 0 day.
You may have to submit a formal support request with Atlassian Support Team as there may be a bug in the AR Cloud version.
Hope this helps.
Best, Joseph Chung Yin
Jira/JSD Functional Lead, Global Infrastructure Applications Team
Viasat Inc.
