Portfolio: Grouping by project in view settings with active filter does not work
bugf1x August 14, 2019
Hi there,
not sure if this came with the last update, the problem is:
  •  I choose more than one project in filters
  • I select group by 'project' in view settings
  • the result is empty
  • group by none or assignee works as intended
this definitely worked before. The same method works for other combinations. When I choose more than one assignee and group by assignee, the result shows me all issues for the assignees and groups by their name.
Chiragkumar Rupani
August 15, 2019
Thanks for sharing your feedback. This is definitely a buggy behavior. I have raised a JAC issue to work on it. You can track the progress by following the JAC issue.
https://jira.atlassian.com/browse/JPOSERVER-2646
If you have any other questions, please feel free to let us know.
Portfolio for Jira
