×The default hierachie in Portfolio is EPIC-> STORY -> SUB-Task
I know how to add additional levels.
Why did Atlassian do it that way? Why is there no TASK level between STORY->TASK?
Why can I not add that level, so that I have
EPIC -> STORY ->TASK -> Sub-Task?
Any idea?
Thanks in advance
Hi Bernd,
The Hierarchy path of EPIC-> STORY -> SUB-Task is a set and default hierarchy path configuration defined by Jira and cannot be changed without add-ons. You can add in levels above the Epic called Initiatives, additional details on the default levels and Inatitive configuration ca be seen here:
To rearrange the default configuration, the App Structure allows for this, and I would recomend checking it out to see if it fits your needs.
Earl
Thank you for your answer. I guess I have to accept this then :-)
