I have 2 questions with Portfolio --> Plan that I created:
1. I don't see the Issues that are closed under the Scope. For the Progress bar to show done v/s open status, wanted to add all the Issues even with Closed/Completed status. Can I manage what Issue status should be included when I create plan? I know i did not filter out the Issues that are closed.
2. How can I create a Plan with the Start date in the past?
Harin
Hi Harin,
Are you using the new Portfolio Planning Experience, or the standard Live Plans on the existing version? If it is the latter:
Hope this helps.
