Best practice for start/end dates in Advanced Roadmaps
Darrel Jackson
I'm starting to roll out Advanced Roadmaps in our organisation. It's a relatively mature Jira instance so it has a number of custom fields for start/end dates depending on the context.
Are there any best practices for selecting which date fields should be used for start date / end date in Advanced Roadmaps? When I create a brand new plan it defaults to "Start Date" (custom field 12010) and "Due Date" (the in-built field).
How do others have this set up?
Are people tracking planned dates and actual dates separately? I'm thinking that's not very relevant when planning using scaled agile techniques.
Darrel Jackson
I'll answer my own question after 16 months of usage.
Best to use Start Date and Due Date. No need for Target/Planned Start and Target/Planned End as any Start Date/Due Date in the future is "target" and any Start Date/Du Date in the past is "actual".
Michelle Schmidt
We're a mature instance but just getting started with Advanced Roadmaps.  We are using Planned Start (custom) and Due Date.
elizabeth_jones
I have custom fields for Target Start, Target End, which is what drives my roadmap gantt chart. I also use start, due date for tracking actuals to plan.
Ari Romanenko
Hey @elizabeth_jones
can you share a bit more on your setup? We are trying to do the same but it seems Warnings are not working on such setup. We want to see a warn when Start date is later than Target start date.
Erin Quick-Laughlin
@elizabeth_jones - we have some teams that follow the same pattern, but I'm curious why we even need Target Start & Target End - what's the value prop?  What does it help improve in your company?
Michelle Schmidt
A Target/Planned Start Date is needed for the Gantt chart, which some people love for sharing as a visualization with Business partners.
Some teams enjoy using the Target/Planned Start Date for managing the backlog - thinking of starting on time helps finish on time, and also helps sort through the clutter of things that don't need to be started until, say, next month.
Erin Quick-Laughlin
I forgot about expectation setting with externals.    Definitely need a separate storage for that.  ;)
