Somehow not able to Parent Link issue within the same projects, while "external" linking works perfectly fine.
Have 2 Jira env, Prod and Test, on Test it works fine, but on Prod something is wrong. Same plugin version, same project, same hierarchy.
Where might be an issue?
Katja
Hi Katja
Do you have same permissions ?
What is parent link issue type ? Epic ?
Mike
Hi Michal,
Same permissions, yes.
Story/Bug to Feature.
Katja
