We are facing the below challenges and are looking to find a way to remove Weekends from Roadmap COnfiguration.
Issue: Weekends are not included in the days of delivery, so they are not counted. Planning the duration for task only includes weekdays.
Solution: Remove weekend in Jira Advance Roadmap Configuration
Hi @Anshuman Bakshi ,
your jira (and as such Advanced Roadmaps) version is important here.
However, it is still possible to use the "old" version if you are already in the new view by going to your plan administration -> Advanced -> Planning interface -> Disable improved interface. (However, this will stop being supported in the near future.)
Hope this helps!
- Tessa
The Near Future has arrived. I don't see this option any more.
I also still don't know how using Teams and capacity eliminates weekends from being counted in total when calculating Days between Target Start and End
Should be 46 Days
