I have an issue filter filtering on components using ScriptRunner and componentMatch. This is combined by an OR clause with a filter on labels. The issue filter works as expected; the isusses are showing up on the board that is input to my Portfolio.
However in Portfolio all issues are visible but only the ones filtered out based on labels are scheduled. The ones filtered out based on componentMatch are not scheduled and thus not included in the plan.
Anyone stumbled on the same problem?
This was a bug that has been corrected in a later version of Scriptrunner (I believe 5.0.15)
Try updating scriptrunning to the latest version and see how it goes!
Thomas
Hi @Thomas
The problem Per-Åke reported is still there even after upgrade of Scriptrunner to 5.2.2.
When label is removed the issue is no longer scheduled. The filter query in board setup looks like this:
NOT (issuetype = epic AND status = done) AND (project in (eliot, ragnar) AND (labels in (SW, SW-TEST) OR component in componentMatch("^sw.*")) OR project = cospa) ORDER BY Rank ASC
Where eliot, ragnar and cospa is projects!
Any suggestions is much appreciated!
/Daniel
Hi @Daniel Miks,
In this case I'd suggest raising an issue with ScriptRunner with those details. The base starting point for support would be http://www.adaptavist.com/w/products-plugins/adaptavist-scriptrunner/scriptrunner-for-jira/
Let met know how that goes.
Thomas
