One filter used in advanced roadmap does not return all the issues in the filter
Leyla Kinaze
Hi, I have a small problem.
I have a filter, filterA =
  •  (issueFunction in issuesinEpics("ProjectA Epics'") and type in (Story) )
when I used use it, it returns 7 stories.
When I try to use the filter in my advance roadmap, it does not return all the 7 stories but only 4 of the stories.
I tried to hardcode the filter, filterB, to see if filter was the issue =
  • key in (story-1, story-2, story-3, story-4, story-5, story-6, story-7)
When I use this filterB, I have the exact same results... I only see 4 stories out of 7 in my advance roadmap.
My plan configuration:
- exclusion rules:  365 days any completed issues - (nothing else is set)
- removed issues: nothing set
The status of the story that I see is are follow:
- 3 in DONE status and the resolved date are in the month of July
- 1 in "IN PROGRESS" status
The status of the story that I do NOT see are as follow:
- all in DONE status and the resolved date are in the month of July as well.
Their respective EPIC are also in DONE status.
Any idea what I'm doing wrong here?  and what I should look at to have a complete roadmap?
Eddie Meardon
July 17, 2024
Hey @Leyla Kinaze
My first thought is that they're being filtered out because they're done, but you seem to have had that thought as well.
Plans actually has a tool that can help you find missing issues. In your Plan settings, go to Find your issue in the sidebar, and search for one of those that doesn't come up. (Full procedure here) This tool should tell you what rule(s) are prohibiting that issue from showing in your plan.
If none of the other troubleshooting options on that page, you may need to reach out to support. They'll be able to see more of what's going on in your site and help you specifically.
I hope this helps
Cheers
Eddie
Leyla Kinaze
Thanks @Eddie Meardon - I think maybe there is a configuration with our Jira instance as I do not see the information you were proposing me to check:
All I see as options in the plan Settings are:
Thank you for your help
Eddie Meardon
July 23, 2024
@Leyla Kinaze are you on a Cloud site or the DC version of Jira?
Leyla Kinaze
Eddie Meardon
July 24, 2024
That explains why you can't see the menu option I mentioned. Sorry about that.
In terms of what help I can offer from DC, we have a page in the documentation about how to find missing issues in Advanced Roadmaps but I think you've done most of these steps.
At this point, I'd recommend reaching out to support.
Like Leyla Kinaze likes this
Leyla Kinaze
Thank you @Eddie Meardon
Avery
Your filters seem accurate, so perhaps it is how the roadmap shows completed issues. Please verify the view settings in the roadmap to check if it hides completed issues. Ensure there are no hidden exclusion rules affecting visibility.
Also, think about timing—sometimes updates can be slow in the roadmap view. Try refreshing or waiting a moment to see if it gets better.
Leyla Kinaze
Hi @Avery ,
Thanks for taking the time to look into my question.
As mentioned in my problem description:
Nothing is set in the exclusion rules nor is there any issues removed in the plan settings.
As for the timing, I have the issue for a week now so it does not look like it is a timing issue.
Will keep looking and possibly raise a support ticket.
Thanks!
Like Avery likes this
Avery
Yeah,  If the issue’s been there for a week, it’s probably not timing.  Contacting support is a solid move. Good luck!
