Plan not visible to others
Peter Riise April 21, 2021
I have made a plan, and no one (even the other "editors" of that plan) only see an empty space when they enter that plan.
I have sent out both the regular link to the plan and a Shared Read-Only link both show an empty plan for all!
Then I enabled Scenarios and then they could see the plan?!?
Is that the correct way to do it or?
Jotter Verhaeghe
June 13, 2022
I experienced a similar issue:
You may be using a filter (to select your content) that is not accessible to the people whom you are sharing your plan with.
Dave
April 21, 2021
Hi @Peter Riise,
That sounds really unusual ... are you on Cloud or Server / DC and if you're on Server which version of Advanced Roadmaps are you using?
Things definitely shouldn't behave in the way in which you're describing,
Dave
I'm on Cloud
Yes really weird.
Like Dave likes this
Dave
April 21, 2021
I think this is worth raising a support request so that we can look into this, could you do this via https://support.atlassian.com/contact please?
Thanks,.
Dave
Like Peter Riise likes this
Peter Riise April 23, 2021
It seem that if i assign a specific user made group to have access instead of "All Advanced Roadmap users" it works.
