Hello! I am using Jira Advanced Roadmaps and have run into an issue. Before I jump into a description of the problem, let me lay out my project settings:
Each epic has an empty "Start date" and "End date" field. My goal is to have the auto scheduler populate these fields according to dependencies, team capacity, and estimations.
This is a test run of the scheduler. I expect the amount of time assigned to a task (circled in blue) to exactly match the estimate in days (circled in blue). What do I need to do to achieve this?
Thanks for your help.
Thanks for your detailed response! The information you provided is immensely helpful. I have a few follow up questions.
1. Yes, so if have 20 hors in the team setting and two members means it will divide 20 hours between two members- hence schedule more days on the plan
2. by using and trail/error :D had to come up with the formula for management :)
Thank you! And kudos to you for reversing the formula. I admire your perseverance.
And for posterity: I ended up switching to Omniplan 3. Omniplan directly uses inputted time estimates as scheduled time for task.
I am confused, to use this functionality to capacity plan over a 6+ month timeline is Jira Product management assuming that teams have 6+ months of work full groomed and estimated at a task/story level?
I have never been part of a team where that is a reality. i.e. epics that are more than 2-3 months out have no tasks/stories assigned to them. How can you capacity plan that?
