when grouping by components on jira advance roadmaps it doesn't bring in the child tickets.
is there a workaround for this or does the component need to be added to each project and each ticket?
Yes, for anything to appear in the grouping, it has to have the relevant field populated (in your case, component).
You could set up automation to populate components on to Stories etc from their Epic, but that still requires the Epic having the data.
@Curt Holley I have the similar issue when Grouping By Releases.
It brings the "Epics" under a release, but does not bring the "Stories" under the Epic.
Any suggestions?
@Unnikrishnan Ramachandran So is it not that the stories do not have the release in the fix version field?
@Curt Holley Thank you! that helped. I was assuming that the Epic - Story relationship would implicitly tie the stories to the Fix Version field.
I explicitly updated the story to have "Fix Version" and it worked.
