Story Mapping tool or Approach when using Advanced Roadmaps
Mike Lemmon
Hi There:
I wanted to reach out to the community to see if anyone that is currently using Advanced Roadmaps, has done Story Mapping in a typical white boarding type session, and if so, what did you use to do your Story Mapping session ... hopefully something that integrates into Jira / Advanced Roadmaps.
Any insights you can provide would be greatly appreciated.
mai.anh April 14, 2021
Hi @Mike Lemmon
I had the same thought with you.
I found a useful third-party plugin for Jira: Agile user story map board & roadmap. It provides both story map and roadmap in only one plugin and also integrate end users persona to share among team. I'm managing & planning multiple projects well now with the it.
Hope this will help.
Mai Anh
Henri Seymour _Easy Agile_
Hey Mai Anh,
Do you happen to work for Dev Samurai, the company that makes Agile User Story Map & Roadmap for Jira
It sounds like it might be a good solution to take whiteboarded story mapping sessions "off the wall" and integrate it with a team's roadmap for Jira users like Mike, but it may be worth being upfront about where you're coming from when recommending it.
I often find myself wanting to recommend the apps I work on at my company, Easy Agile, and people are usually pretty open to it when they understand that you're coming from a team that's got experience in the practice.
Stephanie Seymour, Developer @ Easy Agile
Like Eddy Lambert May likes this
Dave
March 17, 2021
Hey @Mike Lemmon,
This isn't actually something we've done (our team doesn't do story mapping) but I am interested in understanding what your ideal would be in this situation? And how you'd want story mapping to integrate with Advanced Roadmaps? I did notice that there are existing marketplace applications for story mapping (https://marketplace.atlassian.com/search?query=story+map ) but unfortunately I don't have any experience of them.
Dave
