Can anyone help me with the following:
What field in Jira (Epics, Stories) maps to the capacity plan in Jira Plans using Kanban?
I can set-up a team as kanban, allocate tasks to the team. Set the Kanban capacity. The field "Estimates (d)" is used for allocating the workload to the kanban period in the planning. But I can not find this field in the list of field configurations nor customfields in JIRA.
What field do I need to use in the Jira ticket for a kanban board to make that the estimated workload in processed in the Jira Plan
When you're using days to estimate in your Plans that's reflected in the Time Tracking on your Jira Issue. That field will open a pop up where you can enter Time Spent and Time Remaining - it's the Time Remaining value which will show up in the Estimates field in your Plan.
Hope this helps! Please feel free to let me know if there's anything else I can help with here too.
Daniel
Hi Daniel,
Thanks a lot, that was exactly what I was searching for. It works as expected.
regards
Jeroen
