×Hello,
we want to take a look at the advanced roadmaps function, but how can we active it in the trail version?
Hi!
To trial Jira Software Premium do the following:
Go to admin.atlassian.com. Select your organization if you have more than one.
Go to Billing and select your site name.
In the Manage subscriptions page, you’ll see the plan for each product under its subscription details.
Select Change next to the product’s plan.
From the Select plan page, select the plan you want.
Once you did it, the Plans menu would appear in the top navigation. You can watch these 3 short videos to help you get started
I hope it helps!
Thanks a lot, the Plans menu appear on the page.
Create a new Software project or go to an existing project and then navigate to the sidebar and click Roadmap.
1. If you are not seeing your roadmap tab, enable the roadmap in the board setting.
2. Click + create epic on the roadmap to create epics directly on your roadmap.
