We have a client who uses their own JIRA. We periodically do exports and issue Imports to our JIRA to provide certain additional reporting, status, etc.
Has anyone used the automation plugin to do importing of issues? I would be interested if anyone has setup automation for importing.
It might be complicated, because we need to check for duplicates and merge data. but if someone has done a simplistic automation of import, I could take to the next level
Recommended Learning For You
Level up your skills with Atlassian learning
Learning Path
Apply agile practices
Transform how you manage your work with agile practices, including kanban and scrum frameworks.
Learning Path
Configure agile boards for Jira projects
Learn how to create and configure agile Jira boards so you can plan, prioritize, and estimate upcoming work.
Jira Essentials with Agile Mindset
Suitable for beginners, this live instructor-led full-day course will set up your whole team to understand how to use Jira with an agile methodology.
