×My understanding. Please correct if wrong.
The delivery ownership of end solution lies with development team and not scrum master. In traditional method, the project manager is responsible for tracking of product and share the plan to the management. The PM prepares daily plan and has control on the project.
In agile, there is no such concept. There is no commitment to deliver on certain date from development team. Only rough estimation is done and if it is not completed in a sprint, the user stories can be moved to next sprint. Even though we can track the hours spent on daily basis, We can't surely say when the project will be completed?
Every one does their job and update the tasks. If it succeeds, all will get the credit. If it fails, every one sees others faces.
Others view on this please. Thanks
Hi @Prakash R
The team is empowered to make decisions and is solely responsible for shipping work.
They self-organize to complete the tasks in whichever way they think is best, with help from the PO to prioritize.
It is difficult to define success or failure, as there are no due dates or deadlines.
There is simply work to be done and an estimation of capacity into which work is accepted.
A new team will be very poor at estimation - and hopefully improve over time.
Therefore, as a team matures, the ability to predict when work is delivered should improve, but never be guaranteed.
Of course this is much better than the old Project Management way of doing things, where deadlines are arbitrary and budget constrains are laughable.
Sean
Recommended Learning For You
Level up your skills with Atlassian learning
Learning Path
Apply agile practices
Transform how you manage your work with agile practices, including kanban and scrum frameworks.
Learning Path
Configure agile boards for Jira projects
Learn how to create and configure agile Jira boards so you can plan, prioritize, and estimate upcoming work.
Jira Essentials with Agile Mindset
Suitable for beginners, this live instructor-led full-day course will set up your whole team to understand how to use Jira with an agile methodology.
