I am working with Jira as a project manager for almost 12 years now. The projects I am working with are no pyramids and also no huge ones. My projects are from a few hours of a service task (like setting up an eTraining portal and customize the CI) up to some moths of work (like a plugin release). Sometimes it is just one person who does the operational task and sometimes it´s about 15. But we have always some basic tasks like creating invoices, accounting QA or resource planning that are almost every time assigned to the specialist people that take care of it. So any project (even the small ones) contain the work and task for at least 3 people.
So I was always on the hunt for a good and easy solution that helps me setting up projects and their basic tasks very fast and effective (with minimal overhead).
Jira itself seems to be a good choice as it has already the basic functions (issues and workflows). What I was missing is something the can be used as a project folder to keeps things together and standard workflows.
Epic seem to be the answer: Issues as projects.
After several years of using issues as projects and adding some add-ons to make life easier, I am still working with this setup as it allows me to create a project in less than 2 minutes.
This is an essential part of managing a lot of projects at once and stay in control by lean and visual project management.
Now I am looking for other people that are working in the same way and have found ways to handle their projects fast and easy without much setup work.
I would like to discuss several ways of dealing with that job.
Feel free for comments and suggestions.
well I will try to go one by one. ;)
First of all, I let the teams work independently as much as possible. I do this by assigning work packages to the team and give them milestone dates based on what we have estimated first.
Lets stick to this example. When a project is set up, I need to decide, which teams and people are going to do the jobs. in this example 1 development team and 1 accounter.
The dev team does the estimation (in your preferred way) and this will be the base of my proposal(after adding risk budgets). The accounting tasks are well know so I add budgets for these, too. (there might be know risk budgets in your domain that you know quite good).
This part, the estimation and proposal phase is visualized by Epic Sum Up (of course we build it for that). at this stage there is no relation to timelines, as we need the customer to order first. (if the customer wants a time planning already, we do this with Tempo (Team) Planner to make all resources visible for everyone.
The tools that we use here are:
After the customer has ordered the project, we plan the resources (or let the team plan themselves). Main data is the due dates for milestones or parts of the project and the start date(if you need to wait for some reason).
This is in communication with the teams and done with Planner if needed. Some teams are working with SCRUM or on weekly task rounds, some use Kanban Style.
This is done with Jira Agile Boards, Tempo and Epic Sum Up for faster editing.
This part is where the PM wants to see, if the progress matches his expectations. So we put all projects (issues) on a Dashboard (highlevel report) and on a Kanban-Board (project state overview) each of them showing a progress bar from Epic Sum Up again, that shows us: are we on track?
There is a lot of things that we simply do not need in these kind of projects:
oops.. that was a long text though. But that is a small overview of how we can do that with the least minimal setup. A project is running through the flow as a ticket (a large one indeed).
btw: there are more plugins that can do the same job.
Yes. That makes sense, @Andreas Haaken _APTIS_.
It takes out the complexities of running projects with the necessities intact. Thanks for sharing in detail!
Recommended Learning For You
Level up your skills with Atlassian learning
Learning Path
Apply agile practices
Transform how you manage your work with agile practices, including kanban and scrum frameworks.
Learning Path
Configure agile boards for Jira projects
Learn how to create and configure agile Jira boards so you can plan, prioritize, and estimate upcoming work.
Jira Essentials with Agile Mindset
Suitable for beginners, this live instructor-led full-day course will set up your whole team to understand how to use Jira with an agile methodology.
