Connection between Power BI and Timeboard Timeplanner app
Lorenzo Lonati April 8, 2024
Hi! we're trying to connect Power BI for Jira app and Timeboard timeplanner app, but we're not able to find connection with Timeboard tables.
how can we manage it?
thanks!
Annie@DevSamurai
Hi @Lorenzo Lonati
This is Annie from Teamboard TimePlanner. I apologize for the inconvenience, but TimePlanner currently does not support direct integration with Power BI. However, I will take note and discuss it with our development team for future updates.
In the meantime, please don't hesitate to submit a ticket here for any further assistance.
Thanks!
Annie
Anna Odrynska - Alpha Serve
Hi @Lorenzo Lonati
Power BI Connector for Jira application is not supporting data export from Timeboard Timeplanner app at the moment, as they are not integrated. Though, all Tempo apps are supported for export, including Tempo Planner, Timesheets and Cost Tracker.
Anna
Dave Rosenlund _Trundl_
Hi, @Lorenzo Lonati. As you may know, there are a number of Power BI < > Jira apps. And, I think (I could be wrong of course) that you may be referring to TeamBoard TimePlanner for Jira.
In order for the community to offer help to you it's important that we know exactly which products you are using. 🙂
Could you clarify please?
For what it's worth, assuming you mean Power BI Connector for Jira by Alpha Serve and TeamBoard TimePlanner for Jira by DevSamurai, I cannot find any documentation from either of them about connectivity between one and the other.
Hope this helps,
-dave
Dear Dave, thanks for your reply (sorry for missing info)
We’re using Power BI Connector for Jira Cloud (https://aserve.atlassian.net/wiki/spaces/PBCFJC/overview) and teamboard timeplanner for jira
in these cases, there are any other way to connect them?
thank you
