Creating issue links using Clone issue and links post function, in creation transition (JIRA 6.1.2)
Guillaume Robert
April 21, 2017
Here is my scenario:
When creating an issue A, I use the "Clone an issue and links" post function on the creation transition.
This creates a clone issue, issue B, on which I make some operations through "Additional issue actions":
- Update issue B summary, issue B fixverions
- Set issue B specific custom field to a specific value
- Create links between issue B and other issues
With the script below, all the actions related to fields are working, but not the links creation.
Important thing is that the same code works in other context (basic transition for example), and that I get the summary of my issue updated with the relevant Ids of the issues I want to link issue B to:
def issueLinkManager = ComponentAccessor.getIssueLinkManager()
def authenticationContext = ComponentAccessor.getJiraAuthenticationContext()
issue.summary = '[DASHBOARD] ' + sourceIssue.key + ' - ' + issue.summary
issue.fixVersions = new HashSet<String>()
def cfm = ComponentAccessor.getCustomFieldManager()
// customfield_27012 = LPT - Niveau de test
def cf_LPT_NiveauTest = cfm.getCustomFieldObject("customfield_27012")
def om = ComponentAccessor.getOptionsManager()
def cfConfig = cf_LPT_NiveauTest.getRelevantConfig(issue)
def option_DashBoardEvol = om.getOptions(cfConfig).getOptionForValue("DashBoard - Evol", null)
issue.setCustomFieldValue(cf_LPT_NiveauTest, option_DashBoardEvol )
//used for debug
issue.summary = "idLPTTdb=" + sourceIssue.getKey() + " " + issue.summary
issueLinkManager.getInwardLinks(sourceIssue.getId()).each {
  lpttdblink ->
	if (lpttdblink.getIssueLinkType().getName().contains('Traitement BSL')) {
		def idBSL = lpttdblink.getSourceObject()
		//used for debug
		issue.summary = "idBSL=" + idBSL.getKey() + " " + issue.summary
		issueLinkManager.createIssueLink(issue.getId(), idBSL.getId(), new Long(12000), null, authenticationContext.getLoggedInUser())
		idBSL.getSubTaskObjects().each {
			if ((it.getIssueTypeObject().getName().contains("[BSL] Evolution")) && (it.getSummary().contains("[LPI]"))) {
				//used for debug
				issue.summary = "stBSL=" + it.getKey() + " " + issue.summary
				issueLinkManager.createIssueLink(issue.getId(), it.getId(), new Long(12000), null, authenticationContext.getLoggedInUser())
Can anyone help me on this?
Many thanks,
Best regards.
Jonny Carter
April 21, 2017
So, issue linking operations need to be put in the doAfterCreate closure, as described in the docs. So
doAfterCreate = {
        lpttdblink ->
                //used for debug
                        //used for debug
should do it.
Qi Jiang
@Jonny Carter  Is there anyway I can link issue A with issue B here?
Jonny Carter
October 13, 2017
I'm a bit confused. Linking the cloned issue with its original is exactly what the Clone Issue and Link post function already does. Am I misunderstanding which issues are A & B or something??
Qi Jiang
@Jonny Carter When creating an issue A, with  Clone Issue and Link post function, it will generate a clone issue, issue B. But A and B are not linked.
From the online doc I think what that mean is if A is set link to C, then new created clone issue B will also not link to C. But in my case, I want A link to its clone B. Anyway I can do that? If I am wrong could you show me how to link A & B?
Qi Jiang
@Jonny Carter How to get Issue A id and issue B's id, I did try use
sourceIssue.getKey(),sourceIssue.key
but they all return null
Jonny Carter
October 15, 2017
@QQQ - You should be able to specify a link type and direction. From those docs:
Specify also the link type and direction…​ this will normally be Clones, but doesn’t have to be.
As for getting the issue keys in the additional code, sourceIssue.key should work, but it may not work unless you put it inside a doAfterCreate closure. See https://scriptrunner.adaptavist.com/latest/jira/builtin-scripts.html#_after_create_actions.
