Hi All,
Is there a way to add multiple teams to the same project? I have created a leadership team in Atlas and want to add them as contributors or followers. It works in the beginning and disappears after refreshing the link.
Is there a way to resolve this other than adding them individually?
Thank you.
Joseph
Hi Joseph,
It should be possible to add multiple teams to a project by clicking the "+" next to contributors and then clicking the checkbox next to the team avatar to select everyone in that team. You should be able to repeat this to add multiple teams, though you do need to add each team one by one.
What do you mean by "It works in the beginning and disappears after refreshing the link" - are you adding a second team and then the team disappears on refresh?
Mark
Hi Mark, thanks for the response. I have been able to add multiple teams to the project now. It could be a technical issue.
