I'd like to use JQL terms like 'project=XYZ' and get back Altas project and/or goals.
@Chad Wilkes - Couple of things:
1. Atlas doesn't natively support "advanced search" but all searches are backed by something called TQL (Team Query Language). The search filters that are available are all translated to TQL - we just don't expose a way for you to type it in.
2. That said, you can enter parameters in the URL if you're very keen.
3. Otherwise if you just want to search for a specific project or goal key, you can enter the key in search and it will show up.
Hope that helps!
Josh
Thanks Josh. I think to clarify my request just a bit. I'm often trying to address gaps in integration between Atlassian products, particularly Product Discovery <> Atlas <> Jira Software using Automations and want to get values from Atlas into other apps for reference when teams are working on tasks (without having to navigate away from the Epic). Thanks for any additional insights.
I'd like to create a Rovo Agent to create release notes based on the Project updates posted by my team (Projects in the old Atlas sense). I know how I could do this if these Projects were accessible via JQL as a regular Jira board/project, however can this be done from Rovo? Thanks
