I have several interconnected projects in Atlas where I've established dependencies between them using the "related projects" field.
I can currently see these dependencies when I view a project's details in the right column/sidebar, where relationships between projects are displayed. However, I would like to see these dependencies in the timeline view, is this possible?
Hi @gabriella_bailey and welcome to the Community!
No, not as far as I am aware. Atlas projects - now projects in Atlassian Home - are not work items, but intended as communication and context. The timeline can only display links between Jira work items defined by issue links. The related projects section is not defined as such and cannot be represented on a Jira timeline.
While you can display projects in Atlassian Home on a timeline view as well, it does not have the option to display relationships there either.
Hope this helps!
