This is probably more of a training problem but our use case is that our executive team doesn't actually log into Atlas. They just really like the email updates and call it good. So when an messages me to ask to be removed, I have to walk them through the steps instead of just being able to execute the request for them.
Hey @Hans Van Dingenen - indeed you are correct that you can't remove followers from projects like you can add them. Individuals have to explicitly unfollow themselves but will send this to the team for consideration. We may decide to add this functionality in the future.
Would be very helpful for at least administrators
Hi Hans, keen to understand why you want to remove this follower? We've debated this in the past and decided to let the followers decide if they want to unfollow or not. Would love the use-case a bit better
Associates (Business) move on to other positions within the company. Due to their new responsibilities, they have no longer any direct interest in the Project.
Thanks Hans, feels like a legitimate use-case and one you cant rely on the follower to unfollow by themselves. Is there a reason you wouldn't be ok with them remaining a follower?
Trying to understand if this is a case of cleanup to ensure that the followers group remains up-to-date or whether you are approaching this from a security/privacy perspective. Thanks
I'm not the OP, but I have a use case.
I removed an admin account that was following a project. This account still follows the project and keeps getting emails. I can't remove it from following.
Maybe this is more of a cleanup issue (I'd expect that, upon removing an account, that account's project following gets cleaned up too).
At any rate, how can I remove it now?
Id also like to remove followers that I added my mistake (noob)
@Anish Deena I have a user case as well. In Atlas, if you have multiple people with the same name (John Doe), there is no way to distinguish them when you @ mention them in a project. Hugely frustrating - but as soon as you @ mention them in some fields, they are auto added as watches. I would like to remove them once I can figure out who the right John Doe is. If you are worried about people mucking around with others' follow model, simply notify the target user if they have been removed as a follower by someone else.
Hi @Anish Deena we have a deactivated user that has no product or group access that shows up in the follower list.
+1
Project managers and admins need the ability to manage who gets updates on our projects. I think that there are a sufficient number of critical use-cases mentioned here that support the need for this functionality.
I added someone by mistake (very similar names) and I cannot remove the person who has no interest in the project. Would like to manage users in this scenario
um, a person has left the company (???)
@Andrew Hammond Agreeing with the other replies above. One should be able to remove a deactivated user as a Follower since its clutter and no longer relevant. Any updates on that feature request?
@Andrew Hammond is there any update for this? Now ATLAS is Home and widely used (or at least should be accoring to Atlassian).
Showing user details of people who have long left the company is a compliance nightmare. (and all the other use cases mentioned here). Is there any JAC ticket we could upvote at least?
Cheers and thank you in advance,
Christian
Sometimes a person is added inadvertently and will not need to know status. In this case yes, privacy could be an issue.
Some complain and want an Admin to do it vs. clicking a button.
+1 for project owners having capability to administer followers.
We would appreciate a "remove follower" option.
PeterQ
In addition to the above use cases, I added a follower with the wrong email address, and can't remove them now.
+1 -- I added followers to a project as part of testing out this feature, but now would like to limit this list. It's too easy to add followers to a project for it to turn out permanent.
Did you get this resolved? I am running into the same issue
I share all use cases above. I have a set of projects which I added team members to test following, however we haven't gone live with those projects and need to remove them so all the changes I make while preparing the project doesn't update the followers.
Should be available for administrators.
After talking to the Atlassian support they told me to upvote and watch this JAC ticket: https://jira.atlassian.com/browse/ATLAS-124
I'd like to invite all of you to do the same :-)
Thanks and have a great day,
Christian
@Anish Deena Is there any update on whether the ability for admins to remove followers is going to be implemented?
I have a 70+ member of our trustee board who no longer needs updates on certain goals and wants them to stop, but there is no way that she is going to cope with going to Atlas and unfollowing by herself, and every time she gets a no longer wanted update she complains to the CEO.
Why Contributors/Project Admins should have ability to remove a follower in Atlas:
Simply put, there are some business updates here that I don't want the team to see.
Its not clear how long the team will see an update for , even after leaving the company, or if the person is deemed malicious and giving away company updates , I should be able to remove them.
As an admin, I should have this rights on who does, and does not get to follow the project development, including future goals etc
