In Atlas Goals I link Jira issues but once added I cannot see the links anymore.
In the upper part of the picture below I added a Jira Epic to the Goals and it seems ok. But notice that "Contributing Jira issues" say 3, while only the recently added are displayed.
After moving to another section and going back to the same page the link to the Epic has diapered (lower part of below picture).
When looking at the issues in Jira I can see the link to Goals.
My objective is to find a way to track work in Jira at a higher level using Atlas Goals or Projects with links to multiple issues in Jira.
Any advice would be appreciated.
Hi @Janne Magnusson ,
Welcome to the Community! I'm trying to reproduce this issue and it's working for me. I added a few Jira epics linked to Goals and they consistently appear in the 'Jira' tab under the Goals section. Is this issue still happening? What browser are you using? Can you please check with a different browser? Are other users experiencing the same issue? Thanks,
Thanks for your reply. I've tested again in Chrome and Edge, same result. One of my colleges also tested with the same result.
/Janne
