×How to find how many users are using project in jira server?
Hi @khushboo_puri 👋
Good question! To find how many have access simply look at the "application access" section in admin for each one, you will find a list of groups (often there is only one) that has access to it. Then look at the groups for all the users.
If you want it space by space, or project by project, you will have to look at each ones permissions, then who matches those permissions.
If you're trying to find how many are active user from that I'd suggest defining "active" in the UI.
I hope this helps but if you have any other questions just ask away 😃
All the best,
Laura
