Problem with using atlas-create-refapp-plugin-module
carolyn cheng July 8, 2013
When I use this command, I got the following error,
Executing: /usr/share/atlassian-plugin-sdk-4.2.2/apache-maven/bin/mvn com.atlassian.maven.plugins:maven-refapp-plugin:4.2.2:create-plugin-module -gs /usr/share/atlassian-plugin-sdk-4.2.2/apache-maven/conf/settings.xml
[INFO] Scanning for projects...
[INFO] artifact com.atlassian.refapp:atlassian-platform: checking for updates from central
[INFO] artifact com.atlassian.refapp:atlassian-platform: checking for updates from atlassian-public
[INFO] artifact com.atlassian.refapp:atlassian-platform: checking for updates from atlassian-plugin-sdk
[INFO] ------------------------------------------------------------------------
[ERROR] FATAL ERROR
[INFO] Error building POM (may not be this project's POM).
Project ID: com.atlassian.refapp:atlassian-platform
Reason: POM 'com.atlassian.refapp:atlassian-platform' not found in repository: Unable to determine the latest version
com.atlassian.refapp:atlassian-platform:pom:LATEST
for project com.atlassian.refapp:atlassian-platform
[INFO] Trace
org.apache.maven.reactor.MavenExecutionException: POM 'com.atlassian.refapp:atlassian-platform' not found in repository: Unable to determine the latest version
at org.apache.maven.DefaultMaven.getProjects(DefaultMaven.java:432)
at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:300)
at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:137)
at org.apache.maven.cli.MavenCli.main(MavenCli.java:356)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:597)
at org.codehaus.classworlds.Launcher.launchEnhanced(Launcher.java:315)
at org.codehaus.classworlds.Launcher.launch(Launcher.java:255)
at org.codehaus.classworlds.Launcher.mainWithExitCode(Launcher.java:430)
at org.codehaus.classworlds.Launcher.main(Launcher.java:375)
Caused by: org.apache.maven.project.ProjectBuildingException: POM 'com.atlassian.refapp:atlassian-platform' not found in repository: Unable to determine the latest version
at org.apache.maven.project.DefaultMavenProjectBuilder.findModelFromRepository(DefaultMavenProjectBuilder.java:605)
at org.apache.maven.project.DefaultMavenProjectBuilder.buildFromRepository(DefaultMavenProjectBuilder.java:251)
at org.apache.maven.project.DefaultMavenProjectBuilder.mergeManagedDependencies(DefaultMavenProjectBuilder.java:1466)
at org.apache.maven.project.DefaultMavenProjectBuilder.processProjectLogic(DefaultMavenProjectBuilder.java:1008)
at org.apache.maven.project.DefaultMavenProjectBuilder.buildInternal(DefaultMavenProjectBuilder.java:880)
at org.apache.maven.project.DefaultMavenProjectBuilder.buildFromSourceFileInternal(DefaultMavenProjectBuilder.java:508)
at org.apache.maven.project.DefaultMavenProjectBuilder.build(DefaultMavenProjectBuilder.java:200)
at org.apache.maven.DefaultMaven.getProject(DefaultMaven.java:632)
at org.apache.maven.DefaultMaven.collectProjects(DefaultMaven.java:515)
at org.apache.maven.DefaultMaven.getProjects(DefaultMaven.java:419)
... 11 more
Caused by: org.apache.maven.artifact.resolver.ArtifactNotFoundException: Unable to determine the latest version
at org.apache.maven.artifact.transform.LatestArtifactTransformation.transformForResolve(LatestArtifactTransformation.java:44)
at org.apache.maven.artifact.transform.DefaultArtifactTransformationManager.transformForResolve(DefaultArtifactTransformationManager.java:57)
at org.apache.maven.artifact.resolver.DefaultArtifactResolver.resolve(DefaultArtifactResolver.java:145)
at org.apache.maven.artifact.resolver.DefaultArtifactResolver.resolve(DefaultArtifactResolver.java:90)
at org.apache.maven.project.DefaultMavenProjectBuilder.findModelFromRepository(DefaultMavenProjectBuilder.java:558)
... 20 more
[INFO] Total time: 5 seconds
[INFO] Finished at: Mon Jul 08 13:57:33 PDT 2013
[INFO] Final Memory: 2M/81M
Anyone has a reason why?
Brian Topping
The refapp template uses a version of LATEST, but tht doesn't exist in the remote repository. Edit the POM and change that value with something from the list at https://maven.atlassian.com/content/groups/public/com/atlassian/refapp/atlassian-platform/. For instance 2.19.2, though I have not tested that version is specifically compatible with refapp 4.2.4.
Andrian F
Faced a similar issue with plugin sdk 5.0.13 and i used refapp version 2.9.1 and it worked.
Cannot create atlassian-reffapp-plugin-module
