A way to view build plan tasks WITHOUT edit privs?
Tiglath Suriol
December 1, 2017
Does anyone know of a way, other than writing an app that does it though the API, to allow users to view (readonly) a build plan's configuration tasks details, scripts, etc.?
As far as I know it requires Edit privs, but perhaps there is another way.
rsperafico
January 4, 2018
Hello @Tiglath Suriol,
It is required edit permissions in order to view/edit plan configuration. Alternatively, you could review the configuration from database (not straightfoward as it seems though :()
Rafael
