Add capability to remote agent not possible
Deleted user May 26, 2016
I Installed with success the remote agent on a Mac machine, and now I would like to add capabilities to this remote agent, but even if I see my remote agent on the list, I can't click it (in order to add capabilities).
Agents_summary_-_Atlassian_Bamboo.pngWhy?
Rich Duncan
May 26, 2016
See the following on adding capabilities to a remote agent:
https://confluence.atlassian.com/bamboo/configuring-remote-agent-capabilities-using-bamboo-capabilities-properties-289276849.html
Note also that unless this issue was fixed, if you change the capabilities of a remote agent, you need to delete the server definition in Bamboo and then restart the agent to see the new capabilities.
Alexey Chystoprudov
May 26, 2016
Hello @Terence,
It's not enabled because this tab should be used to Approve/Decline remote agents, once they approved by admin and become online you can manage their capabilities
