Bamboo Bitbucket Connection issues
UnderminerStudios January 10, 2017
Hi all,
I have the systems linked and Bamboo even tells me that it knows the Bitbucket server. I can not connect though.  The Bamboo server is windows and the Bitbucket is linux but I have no other issues with different computers.
Here is the log.
Thanks in advance,
Tim
com.atlassian.bamboo.repository.RepositoryException: com.atlassian.bamboo.executor.CancelException
	at com.atlassian.bamboo.v2.trigger.DefaultChangeDetectionManager.collectChangesSinceLastBuildInternal(DefaultChangeDetectionManager.java:393)
	at com.atlassian.bamboo.v2.trigger.DefaultChangeDetectionManager.collectChangesSinceRevisions(DefaultChangeDetectionManager.java:310)
	at com.atlassian.bamboo.v2.trigger.DefaultChangeDetectionManager.collectChangesSinceRevisions(DefaultChangeDetectionManager.java:200)
	at com.atlassian.bamboo.v2.trigger.DefaultChangeDetectionManager.collectAllChangesSinceLastBuild(DefaultChangeDetectionManager.java:157)
	at com.atlassian.bamboo.v2.trigger.ManualBuildDetectionAction.performDelayedChangeDetection(ManualBuildDetectionAction.java:172)
	at com.atlassian.bamboo.chains.ChainExecutionManagerImpl$1.getChainState(ChainExecutionManagerImpl.java:243)
	at com.atlassian.bamboo.chains.ChainExecutionManagerImpl.tryStartChainState(ChainExecutionManagerImpl.java:334)
	at com.atlassian.bamboo.chains.ChainExecutionManagerImpl.delayedStart(ChainExecutionManagerImpl.java:232)
	at sun.reflect.GeneratedMethodAccessor1816.invoke(Unknown Source)
	at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
	at java.lang.reflect.Method.invoke(Unknown Source)
	at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:302)
	at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:190)
	at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:157)
	at org.springframework.aop.interceptor.ExposeInvocationInterceptor.invoke(ExposeInvocationInterceptor.java:92)
	at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:179)
	at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:208)
	at com.sun.proxy.$Proxy155.delayedStart(Unknown Source)
	at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:202)
	at com.atlassian.bamboo.plan.PlanExecutionManagerImpl$1$1$1.lambda$call$0(PlanExecutionManagerImpl.java:413)
	at com.atlassian.bamboo.util.CacheAwareness$3.call(CacheAwareness.java:159)
	at com.atlassian.bamboo.util.CacheAwareness$3.call(CacheAwareness.java:155)
	at com.atlassian.bamboo.util.CacheAwareness.withValuesOlderThanTimestampReloaded(CacheAwareness.java:188)
	at com.atlassian.bamboo.util.CacheAwareness.withValuesOlderThanTimestampReloaded(CacheAwareness.java:154)
	at com.atlassian.bamboo.util.CacheAwareness.withValuesOlderThanTimestampReloaded(CacheAwareness.java:219)
	at com.atlassian.bamboo.plan.PlanExecutionManagerImpl$1$1$1.call(PlanExecutionManagerImpl.java:412)
	at com.atlassian.bamboo.plan.PlanExecutionManagerImpl$1$1$1.call(PlanExecutionManagerImpl.java:403)
	at io.atlassian.util.concurrent.ManagedLocks$ManagedLockImpl.withLock(ManagedLocks.java:293)
	at com.atlassian.bamboo.plan.PlanExecutionLockServiceImpl.lock(PlanExecutionLockServiceImpl.java:85)
	at com.atlassian.bamboo.plan.PlanExecutionManagerImpl.doWithProcessLock(PlanExecutionManagerImpl.java:783)
	at com.atlassian.bamboo.plan.PlanExecutionManagerImpl.access$400(PlanExecutionManagerImpl.java:130)
	at com.atlassian.bamboo.plan.PlanExecutionManagerImpl$1$1.run(PlanExecutionManagerImpl.java:397)
	at com.atlassian.bamboo.utils.BambooRunnables$1.run(BambooRunnables.java:51)
	at com.atlassian.bamboo.security.ImpersonationHelper.runWith(ImpersonationHelper.java:31)
	at com.atlassian.bamboo.security.ImpersonationHelper.runWithSystemAuthority(ImpersonationHelper.java:20)
	at com.atlassian.bamboo.security.ImpersonationHelper$1.run(ImpersonationHelper.java:52)
	at java.lang.Thread.run(Unknown Source)
Caused by: com.atlassian.bamboo.executor.CancelException
	at com.atlassian.bamboo.plugins.git.GitCommandProcessor.runCommand(GitCommandProcessor.java:645)
	at com.atlassian.bamboo.plugins.git.GitCommandProcessor.runCommand(GitCommandProcessor.java:593)
	at com.atlassian.bamboo.plugins.git.GitCommandProcessor.runCommand(GitCommandProcessor.java:587)
	at com.atlassian.bamboo.plugins.git.GitCommandProcessor.runInitCommand(GitCommandProcessor.java:273)
	at com.atlassian.bamboo.plugins.git.NativeGitOperationHelper.createLocalRepository(NativeGitOperationHelper.java:379)
	at com.atlassian.bamboo.plugins.git.NativeGitOperationHelper.fetch(NativeGitOperationHelper.java:460)
	at com.atlassian.bamboo.plugins.git.NativeGitOperationHelper.fetch(NativeGitOperationHelper.java:451)
	at com.atlassian.bamboo.plugins.git.v2.GitChangeDetector.lambda$fetchAndCreateEmptyChangeset$1(GitChangeDetector.java:210)
	at com.atlassian.bamboo.plugins.git.v2.GitChangeDetector.fetchAndCreateEmptyChangeset(GitChangeDetector.java:207)
	at com.atlassian.bamboo.plugins.git.v2.GitChangeDetector.collectChanges(GitChangeDetector.java:120)
	at com.atlassian.bamboo.plugins.git.v2.GitChangeDetector.collectChangesSinceRevision(GitChangeDetector.java:50)
	at com.atlassian.bamboo.plugins.stash.v2.BitbucketServerChangeDetector.collectChangesSinceRevision(BitbucketServerChangeDetector.java:29)
	at com.atlassian.bamboo.v2.trigger.DefaultChangeDetectionManager.collectionChangesWithRetry(DefaultChangeDetectionManager.java:559)
	at com.atlassian.bamboo.v2.trigger.DefaultChangeDetectionManager.lambda$createBuildRepositoryChanges$0(DefaultChangeDetectionManager.java:440)
	at com.atlassian.bamboo.variable.CustomVariableContextImpl.withVariableSubstitutor(CustomVariableContextImpl.java:221)
	at com.atlassian.bamboo.v2.trigger.DefaultChangeDetectionManager.collectChangesSinceLastBuildInternal(DefaultChangeDetectionManager.java:385)
	... 41 more
Alexey Chystoprudov
January 11, 2017
It looks like issue with Git command line client at Bamboo server. Please create request at support.atlassian.com
UnderminerStudios January 11, 2017
No help here? This pretty much makes bamboo useless if it can't pull from bitbucket.
