Bamboo Code checkout problem from svn
bsarkar August 8, 2012
I am using bamboo 4.1.1. Previously my code successfully checkedout from SVN and deploy it.
But today while i trying manual build I got "System Error". The error is following....
Is it a bamboo bug or something else?? please help
System Error Details
Build simplyfiIT Build - simplyfiiT : Error encountered while triggering manual build: Build 'SI-****' failed to check SVN repository
(com.atlassian.bamboo.repository.RepositoryException : Build 'SI-****' failed to check SVN repository)
Occurrences: 2
First Occurred: 09 Aug 2012, 2:33:29 AM
Last Occurred: 09 Aug 2012, 2:37:21 AM
com.atlassian.bamboo.repository.RepositoryException: Build 'SI-****' failed to check SVN repository
	at com.atlassian.bamboo.repository.svn.SvnRepository.collectChangesSinceLastBuild(SvnRepository.java:318)
	at com.atlassian.bamboo.v2.trigger.DefaultChangeDetectionManager.collectChangesSinceLastBuild(DefaultChangeDetectionManager.java:252)
	at com.atlassian.bamboo.v2.trigger.DefaultChangeDetectionManager.collectChangesSinceRevisions(DefaultChangeDetectionManager.java:214)
	at com.atlassian.bamboo.v2.trigger.DefaultChangeDetectionManager.collectChangesSinceRevisions(DefaultChangeDetectionManager.java:139)
	at com.atlassian.bamboo.v2.trigger.DefaultChangeDetectionManager.collectAllChangesSinceLastBuild(DefaultChangeDetectionManager.java:128)
	at com.atlassian.bamboo.v2.trigger.ManualBuildDetectionAction.process(ManualBuildDetectionAction.java:92)
	at com.atlassian.bamboo.chains.ChainExecutionManagerImpl.createChainState(ChainExecutionManagerImpl.java:256)
	at com.atlassian.bamboo.chains.ChainExecutionManagerImpl.start(ChainExecutionManagerImpl.java:170)
	at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
	at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
	at java.lang.reflect.Method.invoke(Method.java:601)
	at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:304)
	at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:182)
	at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:149)
	at org.springframework.aop.interceptor.ExposeInvocationInterceptor.invoke(ExposeInvocationInterceptor.java:89)
	at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:171)
	at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:204)
	at $Proxy81.start(Unknown Source)
	at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:198)
	at $Proxy82.start(Unknown Source)
	at com.atlassian.bamboo.plan.PlanExecutionManagerImpl.startWithLockTaken(PlanExecutionManagerImpl.java:249)
	at com.atlassian.bamboo.plan.PlanExecutionManagerImpl.access$100(PlanExecutionManagerImpl.java:40)
	at com.atlassian.bamboo.plan.PlanExecutionManagerImpl$1.call(PlanExecutionManagerImpl.java:236)
	at com.atlassian.bamboo.plan.PlanExecutionManagerImpl$1.call(PlanExecutionManagerImpl.java:230)
	at com.atlassian.util.concurrent.ManagedLocks$ManagedLockImpl.withLock(ManagedLocks.java:324)
	at com.atlassian.bamboo.plan.PlanExecutionLockServiceImpl.lock(PlanExecutionLockServiceImpl.java:68)
	at com.atlassian.bamboo.plan.PlanExecutionManagerImpl.doWithProcessLock(PlanExecutionManagerImpl.java:360)
	at com.atlassian.bamboo.plan.PlanExecutionManagerImpl.start(PlanExecutionManagerImpl.java:229)
	at com.atlassian.bamboo.plan.PlanExecutionManagerImpl.startManualExecution(PlanExecutionManagerImpl.java:152)
	at com.atlassian.bamboo.plan.PlanExecutionManagerImpl.startManualExecution(PlanExecutionManagerImpl.java:112)
	at com.atlassian.bamboo.v2.ww2.build.TriggerManualBuild.doExecute(TriggerManualBuild.java:46)
	at com.atlassian.bamboo.ww2.BambooActionSupport.execute(BambooActionSupport.java:1025)
	at sun.reflect.GeneratedMethodAccessor278.invoke(Unknown Source)
	at com.opensymphony.xwork.DefaultActionInvocation.invokeAction(DefaultActionInvocation.java:358)
	at com.opensymphony.xwork.DefaultActionInvocation.invokeActionOnly(DefaultActionInvocation.java:218)
	at com.opensymphony.xwork.DefaultActionInvocation.invoke(DefaultActionInvocation.java:192)
	at com.opensymphony.xwork.interceptor.DefaultWorkflowInterceptor.doIntercept(DefaultWorkflowInterceptor.java:175)
	at com.atlassian.bamboo.ww2.interceptors.BambooWorkflowInterceptor.validateWorkflow(BambooWorkflowInterceptor.java:52)
	at com.atlassian.bamboo.ww2.interceptors.BambooWorkflowInterceptor.access$000(BambooWorkflowInterceptor.java:15)
	at com.atlassian.bamboo.ww2.interceptors.BambooWorkflowInterceptor$1.call(BambooWorkflowInterceptor.java:32)
	at com.atlassian.bamboo.ww2.interceptors.BambooWorkflowInterceptor$1.call(BambooWorkflowInterceptor.java:28)
	at com.atlassian.bamboo.util.BambooProfilingUtils.withUtilTimerStack(BambooProfilingUtils.java:49)
	at com.atlassian.bamboo.ww2.interceptors.BambooWorkflowInterceptor.doIntercept(BambooWorkflowInterceptor.java:27)
	at com.opensymphony.xwork.interceptor.MethodFilterInterceptor.intercept(MethodFilterInterceptor.java:86)
	at com.opensymphony.xwork.DefaultActionInvocation.invoke(DefaultActionInvocation.java:190)
	at com.opensymphony.xwork.validator.ValidationInterceptor.doIntercept(ValidationInterceptor.java:116)
	at com.atlassian.bamboo.ww2.interceptors.BambooValidationInterceptor.validate(BambooValidationInterceptor.java:48)
	at com.atlassian.bamboo.ww2.interceptors.BambooValidationInterceptor.access$000(BambooValidationInterceptor.java:12)
	at com.atlassian.bamboo.ww2.interceptors.BambooValidationInterceptor$1.call(BambooValidationInterceptor.java:28)
	at com.atlassian.bamboo.ww2.interceptors.BambooValidationInterceptor$1.call(BambooValidationInterceptor.java:24)
	at com.atlassian.bamboo.ww2.interceptors.BambooValidationInterceptor.doIntercept(BambooValidationInterceptor.java:23)
	at com.atlassian.bamboo.ww2.interceptors.JSONValidationInterceptor.doIntercept(JSONValidationInterceptor.java:68)
	at com.atlassian.bamboo.ww2.interceptors.AbstractBambooInterceptor$1.call(AbstractBambooInterceptor.java:36)
	at com.atlassian.bamboo.ww2.interceptors.AbstractBambooInterceptor$1.call(AbstractBambooInterceptor.java:32)
	at com.atlassian.bamboo.ww2.interceptors.AbstractBambooInterceptor.intercept(AbstractBambooInterceptor.java:31)
	at com.atlassian.bamboo.ww2.interceptors.SimpleConversionErrorInterceptor.intercept(SimpleConversionErrorInterceptor.java:78)
	at com.opensymphony.xwork.interceptor.AroundInterceptor.intercept(AroundInterceptor.java:31)
	at com.opensymphony.webwork.interceptor.FileUploadInterceptor.intercept(FileUploadInterceptor.java:174)
	at com.opensymphony.xwork.interceptor.I18nInterceptor.intercept(I18nInterceptor.java:151)
	at com.atlassian.bamboo.security.acegi.intercept.web.WebworkSecurityInterceptor.intercept(WebworkSecurityInterceptor.java:54)
	at com.atlassian.bamboo.security.acegi.intercept.web.WebworkSecurityInterceptorProxy.intercept(WebworkSecurityInterceptorProxy.java:30)
	at com.atlassian.bamboo.ww2.interceptors.PaginationAwareInterceptor.doIntercept(PaginationAwareInterceptor.java:98)
	at com.atlassian.bamboo.ww2.interceptors.StatisticsAwareInterceptor.doIntercept(StatisticsAwareInterceptor.java:38)
	at com.atlassian.bamboo.ww2.interceptors.ResultsListAwareInterceptor.doIntercept(ResultsListAwareInterceptor.java:41)
	at com.atlassian.bamboo.ww2.interceptors.NavigationAwareInterceptor.doIntercept(NavigationAwareInterceptor.java:93)
	at com.atlassian.bamboo.ww2.interceptors.BuildResultsSummaryAwareInteceptor.doIntercept(BuildResultsSummaryAwareInteceptor.java:61)
	at com.atlassian.bamboo.ww2.interceptors.ResultsSummaryAwareInteceptor.doIntercept(ResultsSummaryAwareInteceptor.java:69)
	at com.atlassian.bamboo.ww2.interceptors.ChainAwareInterceptor.doIntercept(ChainAwareInterceptor.java:112)
	at com.opensymphony.xwork.interceptor.ExceptionMappingInterceptor.intercept(ExceptionMappingInterceptor.java:186)
	at com.opensymphony.xwork.DefaultActionProxy.execute(DefaultActionProxy.java:116)
	at com.opensymphony.webwork.dispatcher.DispatcherUtils.serviceAction(DispatcherUtils.java:274)
	at com.opensymphony.webwork.dispatcher.FilterDispatcher.doFilter(FilterDispatcher.java:202)
	at com.atlassian.bamboo.ww2.BambooFilterDispatcher.doFilter(BambooFilterDispatcher.java:30)
	at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1331)
	at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:46)
	at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:66)
	at com.atlassian.applinks.core.rest.context.ContextFilter.doFilter(ContextFilter.java:25)
	at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:74)
	at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42)
	at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:77)
	at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:63)
	at com.opensymphony.module.sitemesh.filter.PageFilter.parsePage(PageFilter.java:118)
	at com.opensymphony.module.sitemesh.filter.PageFilter.doFilter(PageFilter.java:52)
	at com.opensymphony.webwork.dispatcher.ActionContextCleanUp.doFilter(ActionContextCleanUp.java:88)
	at com.atlassian.bamboo.filter.BambooProfilingFilter.doFilter(BambooProfilingFilter.java:30)
	at com.atlassian.bamboo.filter.AccessLogFilter.doFilter(AccessLogFilter.java:66)
	at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:265)
	at org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java:125)
	at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275)
	at com.atlassian.bamboo.filter.SeraphLoginFilter.doFilter(SeraphLoginFilter.java:71)
	at org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:149)
	at org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98)
	at com.atlassian.bamboo.filter.BambooAcegiProxyFilter.doFilter(BambooAcegiProxyFilter.java:25)
	at com.atlassian.bamboo.filter.LicenseFilter.doFilter(LicenseFilter.java:73)
	at com.atlassian.core.filters.AbstractHttpFilter.doFilter(AbstractHttpFilter.java:31)
	at com.atlassian.johnson.filters.AbstractJohnsonFilter.doFilter(AbstractJohnsonFilter.java:71)
	at com.atlassian.seraph.filter.SecurityFilter.doFilter(SecurityFilter.java:211)
	at com.atlassian.seraph.filter.BaseLoginFilter.doFilter(BaseLoginFilter.java:150)
	at com.atlassian.seraph.filter.BambooLoginFilter.doFilter(BambooLoginFilter.java:34)
	at com.atlassian.oauth.serviceprovider.internal.servlet.OAuthFilter.doFilter(OAuthFilter.java:71)
	at com.atlassian.security.auth.trustedapps.filter.TrustedApplicationsFilter.doFilter(TrustedApplicationsFilter.java:98)
	at org.springframework.orm.hibernate.support.OpenSessionInViewFilter.doFilterInternal(OpenSessionInViewFilter.java:170)
	at com.atlassian.bamboo.persistence.BambooSessionInViewFilter.doFilterInternal(BambooSessionInViewFilter.java:31)
	at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:75)
	at com.planetj.servlet.filter.compression.CompressingFilter.handleDoFilter(CompressingFilter.java:203)
	at com.planetj.servlet.filter.compression.CompressingFilter.doFilter(CompressingFilter.java:193)
	at com.atlassian.bamboo.filter.CompressingFilter.doFilter(CompressingFilter.java:71)
	at com.atlassian.bamboo.filter.RequestCacheThreadLocalFilter.doFilter(RequestCacheThreadLocalFilter.java:31)
	at org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:96)
	at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:477)
	at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:119)
	at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:524)
	at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:227)
	at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1031)
	at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:406)
	at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:186)
	at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:965)
	at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:117)
	at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:111)
	at org.eclipse.jetty.server.Server.handle(Server.java:349)
	at org.eclipse.jetty.server.AbstractHttpConnection.handleRequest(AbstractHttpConnection.java:452)
	at org.eclipse.jetty.server.AbstractHttpConnection.headerComplete(AbstractHttpConnection.java:884)
	at org.eclipse.jetty.server.AbstractHttpConnection$RequestHandler.headerComplete(AbstractHttpConnection.java:938)
	at org.eclipse.jetty.http.HttpParser.parseNext(HttpParser.java:634)
	at org.eclipse.jetty.http.HttpParser.parseAvailable(HttpParser.java:230)
	at org.eclipse.jetty.server.AsyncHttpConnection.handle(AsyncHttpConnection.java:77)
	at org.eclipse.jetty.io.nio.SelectChannelEndPoint.handle(SelectChannelEndPoint.java:609)
	at org.eclipse.jetty.io.nio.SelectChannelEndPoint$1.run(SelectChannelEndPoint.java:45)
	at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:599)
	at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:534)
	at java.lang.Thread.run(Thread.java:722)
Caused by: org.tmatesoft.svn.core.SVNAuthenticationException: svn: Authentication required for '<https://svn.******.co.us:8459> Login with your SID'
	at org.tmatesoft.svn.core.internal.wc.SVNErrorManager.authenticationFailed(SVNErrorManager.java:47)
	at org.tmatesoft.svn.core.internal.wc.SVNErrorManager.authenticationFailed(SVNErrorManager.java:41)
	at org.tmatesoft.svn.core.internal.wc.DefaultSVNAuthenticationManager.getNextAuthentication(DefaultSVNAuthenticationManager.java:214)
	at org.tmatesoft.svn.core.internal.io.dav.http.HTTPConnection.request(HTTPConnection.java:568)
	at org.tmatesoft.svn.core.internal.io.dav.http.HTTPConnection.request(HTTPConnection.java:280)
	at org.tmatesoft.svn.core.internal.io.dav.http.HTTPConnection.request(HTTPConnection.java:268)
	at org.tmatesoft.svn.core.internal.io.dav.DAVConnection.exchangeCapabilities(DAVConnection.java:536)
	at org.tmatesoft.svn.core.internal.io.dav.DAVConnection.open(DAVConnection.java:98)
	at org.tmatesoft.svn.core.internal.io.dav.DAVRepository.openConnection(DAVRepository.java:1009)
	at org.tmatesoft.svn.core.internal.io.dav.DAVRepository.getLatestRevision(DAVRepository.java:180)
	at org.tmatesoft.svn.core.wc.SVNBasicClient.getRevisionNumber(SVNBasicClient.java:482)
	at org.tmatesoft.svn.core.wc.SVNBasicClient.getLocations(SVNBasicClient.java:876)
	at org.tmatesoft.svn.core.wc.SVNBasicClient.createRepository(SVNBasicClient.java:534)
	at org.tmatesoft.svn.core.wc.SVNWCClient.doInfo(SVNWCClient.java:2571)
	at org.tmatesoft.svn.core.wc.SVNWCClient.doInfo(SVNWCClient.java:2901)
	at com.atlassian.bamboo.repository.svn.SvnRepository.doInfo(SvnRepository.java:1189)
	at com.atlassian.bamboo.repository.svn.SvnRepository.detectCommitsForUrl(SvnRepository.java:422)
	at c
LucasA
November 14, 2012
If you still facing this problem, please raise a support tiket at https://support.atlassian.com.
Lucas Lima
Atlassian Support
James Dumay
August 8, 2012
Hi biswajit,
Please file a ticket with Atlassaian support and they will be able to help you sort this out.
James
anyone aware with this problem.....
is it a bamboo bug??
please help...its urgent
