Bamboo Plan/Project Codes
Adrian Williams
July 26, 2017
I have set the plan and project codes for a new plan but unlike ealier plans the codes are not used in the directory structure instead i get a generic plan-32669697 directory
Alexey Chystoprudov
July 26, 2017
yes, folder structure was changed to make it independent from project-plan key. These keys are changed when project moved to another project which makes this operation non-transactional
