Bamboo Remote Agent Problem: URI has an authority component
Robin Gauß October 5, 2015
I have a problem with one of my remote agents. When starting the agent I see the following errors in the log file:
Exiting due to fatal exception.
java.lang.IllegalArgumentException: URI has an authority component
   at java.io.File.<init>(Unknown Source)
   at com.atlassian.bamboo.agent.bootstrap.BootstrapUpdater.ensureLatestBootstrap(BootstrapUpdater.java:36)
   at com.atlassian.bamboo.agent.bootstrap.AgentContext.updateBootstrapIfNecessary(AgentContext.java:203)
   at com.atlassian.bamboo.agent.bootstrap.AgentContext.initServerSession(AgentContext.java:104)
   at com.atlassian.bamboo.agent.bootstrap.AgentContext.run(AgentContext.java:94)
   at com.atlassian.bamboo.agent.bootstrap.AgentBootstrap.run(AgentBootstrap.java:95)
   at com.atlassian.bamboo.agent.bootstrap.AgentBootstrap.main(AgentBootstrap.java:41)
   at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
   at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
   at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
   at java.lang.reflect.Method.invoke(Unknown Source)
   at org.tanukisoftware.wrapper.WrapperSimpleApp.run(WrapperSimpleApp.java:240)
   at java.lang.Thread.run(Unknown Source)
FATAL [WrapperSimpleAppMain] [AgentBootstrap] Exiting due to fatal exception.
JVM exited while starting the application.
I checked the Java version and architecture, the config file for the wrapper and the agent and couldn't find any difference to the other Remote Agents that I use. The system Path variable looks good as well.
Remote Agent Infos:
OS: Windows 7 x64
Jdk: 1.8_60 x64 by Oracle
Wrapper / Remote Agent Version: Version 3.2.3-atlassian-1
Bamboo Version: 5.9.4
Any help is highly appreciated.
Robin Gauß October 12, 2015
I found it out myself.
The problem was caused by a network share of the standard installation path. The path was shared before the bamboo agent got installed. Somehow the installation batch for the service used the UNC path for the call of the agent rather than the local path. It worked after removing the share of the folder and reinstalling the whole agent.
Make sure to check the "Path to executable" in the Windows service if you run into a similar problem.
Przemek Bruski
October 5, 2015
What is the full path of your atlassian-bamboo-agent-bootstrap.jar ?
I guess you mean the bamboo-agent-bootstrap.jar Full path: C:\Users\[UserID]\bamboo-agent-home\lib\bamboo-agent-bootstrap.jar The UserID contains no blanks or special characters it's like abc123.
rsperafico
October 6, 2015
Hello Robin, The file requested is "atlassian-bamboo-agent-bootstrap-5.9.4.jar": * under "<bamboo-install>/atlassian-bamboo/WEB-INF/lib" * under "<bamboo-agent-home>/classpath" — Kind regards, Rafael P. Sperafico Atlassian Support
Robin Gauß October 6, 2015
Alright, the paths are: E:\Atlassian\Bamboo\atlassian-bamboo\WEB-INF\lib\atlassian-bamboo-agent-bootstrap-5.9.4.jar or \\[Hostname]\Atlassian\Bamboo\atlassian-bamboo\WEB-INF\lib\atlassian-bamboo-agent-bootstrap-5.9.4.jar and C:\Users\[UserID]\bamboo-agent-home\classpath\atlassian-bamboo-agent-core-5.9.4.jar
Przemek Bruski
October 8, 2015
How do you start your agent?
Robin Gauß October 8, 2015
I used the included batches to create a Windows service. Something strange happened today. After reinstalling the whole agent, the process agent that got started by the installation process was working correct. The service that I installed afterwards failed again with the same error like before. So I guess it has something to do with the service. The service is set up to use the account of the main PC user which also has local admin rights on the machine and can write to the user directory where the builds are happening. Maybe this has something to do with it? This setup is also used on the other 3 remote agents that are working with no problem. But maybe I missed something.
Przemek Bruski
October 8, 2015
What I think happens is that for some reason the agent determines its location using an UNC path and that does not work.
