I'm bringing up my 18th remote agent and I am hitting something I haven't seen.
INFO | jvm 5 | 2016/04/07 10:41:21 | WARNING - Unable to load the Wrapper's native library 'libwrapper.so'.
INFO | jvm 5 | 2016/04/07 10:41:21 | The file is located on the path at the following location but
INFO | jvm 5 | 2016/04/07 10:41:21 | could not be loaded:
INFO | jvm 5 | 2016/04/07 10:41:21 | XXXXXXX/bin/../lib/libwrapper.so
INFO | jvm 5 | 2016/04/07 10:41:21 | Please verify that the fileis readable by the current user
INFO | jvm 5 | 2016/04/07 10:41:21 | and that the file has not been corrupted in any way.
INFO | jvm 5 | 2016/04/07 10:41:21 | One common cause of this problem is running a 32-bit version
INFO | jvm 5 | 2016/04/07 10:41:21 | of the Wrapper with a 64-bit version of Java, or vica versa.
INFO | jvm 5 | 2016/04/07 10:41:21 | This is a 32-bit JVM.
IT did put a 64 bit Java on this machine. Is there a 64 bit JVM I can download? Or do I need a different Java?
I deleted the bamboo home and started over. All I did was change to use a different URL for the agentServer. Go figure.
]$ java -d32
Error: This Java instance does not support a 32-bit JVM.
Please install the desired version.
$ echo $JAVA_HOME
/common/local/jre1.7.0_75
Hi Mark,
Can you please ensure that you have Java 64bit installed in the machine in which you're trying to install the remote agent? Also, please configure JAVA_HOME accordingly.
You can check the Java settings by running the following commands:
echo %JAVA_HOME%
- if on Windowsecho $JAVA_HOME
- if on Linux / Macjava -version
I hope this helps!
INFO | jvm 5 | 2016/04/07 10:41:21 | Reported cause:
INFO | jvm 5 | 2016/04/07 10:41:21 | XXXXXXX/lib/libwrapper.so: XXXXXXX/lib/libwrapper.so: wrong ELF class: ELFCLASS64 (Possible cause: architecture word width mismatch)
