×Specifically, use an EBS Snapshot attached to your image, as described here:
https://confluence.atlassian.com/display/BAMBOO/Configuring+elastic+instances+to+use+the+EBS
It even automatically will copy over the .m2/settings.xml for you.
Generally in this case I would add a profile to the settings.xml on your bamboo server that specifies to use your nexus repository. Then if you are building other maven built projects that you don't want to change their pom.xml (i.e adding your nexus repo in there as well) then just specify the profile in the build setup in bamboo for that project. i.e. -P ProfileName
It should then find the profile defined in your settings.xml and use the maven servers there to fetch dependencies
Yes, This is more or less what I do.
But here, I'm talking about the import of a Maven project feature .
When I point the import process to our maven project (which builds fine when creating the maven task manually), the import process fails and in the errors I see it tried to connect directly to maven cerntral and other external maven repositories.
The question is then, why doesn't he use the maven settings ?
