Bamboo remote agent 5.13.0.1 not working inside alpine 3.4 docker container
Laurent POCHON September 30, 2016
I try to setup a bamboo remote agent on alpine 3.4 docker container.
It is working perfectly in my centos:7 container, but i can not make it work inside my alipine container.
The master is working perfectly inside alpine container, but i have some problems with the remote agents.
Here is my error :
Running [/opt/atlassian/bamboo-agent-home/bin/bamboo-agent.sh, console]
Agent process started, shutdown hook registered, proceeding with log pump...
Running Bamboo Agent...
"/opt/atlassian/bamboo-agent-home/bin/./wrapper" "/opt/atlassian/bamboo-agent-home/bin/../conf/wrapper.conf" wrapper.syslog.ident=bamboo-agent wrapper.pidfile="/opt/atlassian/bamboo-agent-home/bin/./bamboo-agent.pid" wrapper.lockfile="/var/lock/subsys/bamboo-agent"
/opt/atlassian/bamboo-agent-home/bin/bamboo-agent.sh: eval: line 1: /opt/atlassian/bamboo-agent-home/bin/./wrapper: not found
Waiting for the agent process to finish...
Underlying agent process has terminated cleanly,
Bamboo Agent Installer is shutting down, the underlying agent process has already been shut down.
the failing command is : /opt/atlassian/bamboo-agent-home/bin/./wrapper /opt/atlassian/bamboo-agent-home/bin/../conf/wrapper.conf wrapper.syslog.ident=bamboo-agent wrapper.pidfile="/opt/atlassian/bamboo-agent-home/bin/./bamboo-agent.pid" wrapper.lockfile="/var/lock/subsys/bamboo-agent"
Here is a view of my file system :
bamboo-remote-agent-a1:/opt/atlassian/bamboo-agent-home/bin# ll /opt/atlassian/bamboo-agent-home/bin/./wrapper
-rwxr-xr-x 1 root root 117740 Sep 30 09:28 /opt/atlassian/bamboo-agent-home/bin/./wrapper
bamboo-remote-agent-a1:/opt/atlassian/bamboo-agent-home/bin# ll /opt/atlassian/bamboo-agent-home/bin/../conf/wrapper.conf
-rw-r--r-- 1 root root 2466 Sep 30 09:28 /opt/atlassian/bamboo-agent-home/bin/../conf/wrapper.conf
total 132
-rwxr-xr-x 1 root root 15102 Sep 30 09:48 bamboo-agent.sh
-rwxr-xr-x 1 root root 117740 Sep 30 09:28 wrapper
bamboo-remote-agent-a1:/opt/atlassian/bamboo-agent-home/bin# ll /var/lock/subsys/
total 0
Here is the Dockerfile
# Use alpine version which is really lighter
FROM openjdk:8-alpine
ENV BAMBOO_JAR_PATH /opt/atlassian/atlassian-bamboo-agent-installer-5.13.0.1.jar
# Setup some evironnement variables
ENV container docker
# Upgrade alpine
RUN apk -U upgrade
# Add packages
RUN echo "http://dl-4.alpinelinux.org/alpine/edge/testing" >> /etc/apk/repositories && \
apk --update add \
iputils \
bash \
vim \
curl \
wget \
make \
git \
tomcat-native \
gzip \
php5 \
php5-cli \
php5-common \
php5-fpm \
php5-gd \
php5-imap \
php5-intl \
php5-mcrypt \
php5-mysqli \
php5-opcache \
php5-pgsql \
php5-soap \
php5-xml \
&& rm -rf /var/cache/apk/*
# Install bamboo remote agent
RUN mkdir /opt && mkdir /opt/atlassian
ADD conf${BAMBOO_JAR_PATH} ${BAMBOO_JAR_PATH}
CMD java -Dbamboo.home=/opt/atlassian/bamboo-agent-home/ -jar ${BAMBOO_JAR_PATH} http://bamboo-master:8085/agentServer/
Any idea ? Is the wrapper working with Alpine ?
Przemek Bruski
September 30, 2016
Alpine is most likely missing the dl libs required to run the wrapper. I don't think there's a workaround, you should use the agent without the wrapper.
Przemek Bruski
October 2, 2016
Something like that should work:
java -classpath bamboo-agent-bootstrap.jar  com.atlassian.bamboo.agent.bootstrap.AgentBootstrap http://localhost:8085/bamboo/agentServer
Dave Chevell
July 28, 2017
I did some research into this, and @Przemek Bruski 100% right: Alpine swaps out glibc for musl libc, and the wrapper is dynamically linked against glibc libraries. You can see this in Alpine by running ldd against the wrapper:
bash-4.3# ldd bin/wrapper
/lib64/ld-linux-x86-64.so.2 (0x55e5f5866000)
libm.so.6 => /lib64/ld-linux-x86-64.so.2 (0x55e5f5866000)
libpthread.so.0 => /lib64/ld-linux-x86-64.so.2 (0x55e5f5866000)
libc.so.6 => /lib64/ld-linux-x86-64.so.2 (0x55e5f5866000)
Error relocating bin/wrapper: __fprintf_chk: symbol not found
Error relocating bin/wrapper: __printf_chk: symbol not found
Error relocating bin/wrapper: __memcpy_chk: symbol not found
Error relocating bin/wrapper: __vsnprintf_chk: symbol not found
Error relocating bin/wrapper: __read_chk: symbol not found
Error relocating bin/wrapper: __strcpy_chk: symbol not found
Error relocating bin/wrapper: __syslog_chk: symbol not found
Error relocating bin/wrapper: __sprintf_chk: symbol not found
Error relocating bin/wrapper: __realpath_chk: symbol not found
If you want to use the wrapper, the solution is to install glibc into your Alpine container. For example:
RUN apk --no-cache add ca-certificates \
&& wget -q -O /etc/apk/keys/sgerrand.rsa.pub https://raw.githubusercontent.com/sgerrand/alpine-pkg-glibc/master/sgerrand.rsa.pub \
&& wget https://github.com/sgerrand/alpine-pkg-glibc/releases/download/2.25-r0/glibc-2.25-r0.apk \
&& apk add glibc-2.25-r0.apk
(The above was found in https://github.com/sgerrand/alpine-pkg-glibc)
I maintain my own Bamboo agent Docker image: https://bitbucket.org/dchevell/docker-bamboo-base-agent/overview and I've just switched it to Alpine, and ran into the same issue. Making the above change resolved the issue and added about 10MB to the size of the image (uncompressed).
Please note: whilst I work for Atlassian support, the above is just a personal repo intended for illustration purposes and is not official or supported in any way.
