Bamboo upgrade 5.10 to 6.x, as per path first need to upgrade 5.14
pawan singh chouhan
August 9, 2019
We are currently using Bamboo 5.10 and we wanted to upgrade to latest version, so as per upgrade path we first need to upgrade to 5.14 then only we can move to 6.x version.
So do we need to buy license for both 5.14 and 6.x or is it possible to upgrade that we upgrade to 5.14 trial version and then upgrade to 6.x with the license key.
Edwin Kyalangalilwa
August 9, 2019
Hi @pawan singh chouhan ,
You can use the same license key. And yes, you can use a trial license and then switch once you get to 5.14.
pawan singh chouhan
August 12, 2019
Thanks for your help :)
