Bamboo with Perforce - Need help with the first build
Divya Jain March 17, 2020
I am new to Bamboo, installed a trial version (Atlassian Bamboo version 6.10.4 ) on windows and did an Express Installation and trying to set up a CI set up using Bamboo and Perforce.
My code is at perforce at a location //depot/abc/xyz
I created server capability, set up the Perforce repository.
Depot view - //client_name/depot/abc/xyz...
When I am started the first build, the error is like -
com.atlassian.bamboo.repository.RepositoryException: Could not retrieve latest change number for <depot view>
	at com.atlassian.bamboo.repository.perforce.PerforceManager.getLatestChangeNumber(PerforceManager.java:356)
	at com.atlassian.bamboo.repository.perforce.PerforceRepository.collectChangesSinceLastBuild(PerforceRepository.java:147)
	at com.atlassian.bamboo.vcs.configuration.legacy.LegacyChangeDetector.collectChangesSinceRevision(LegacyChangeDetector.java:54)
	at com.atlassian.bamboo.v2.trigger.DefaultChangeDetectionManager.collectionChangesWithRetry(DefaultChangeDetectionManager.java:577)
	at com.atlassian.bamboo.v2.trigger.DefaultChangeDetectionManager.lambda$createBuildRepositoryChanges$2(DefaultChangeDetectionManager.java:476)
	at com.atlassian.bamboo.variable.CustomVariableContextImpl.withVariableSubstitutor(CustomVariableContextImpl.java:185)
	at com.atlassian.bamboo.v2.trigger.DefaultChangeDetectionManager.collectChangesSinceLastBuildInternal(DefaultChangeDetectionManager.java:437)
	at com.atlassian.bamboo.v2.trigger.DefaultChangeDetectionManager.collectChangesSinceRevisions(DefaultChangeDetectionManager.java:287)
	at com.atlassian.bamboo.v2.trigger.DefaultChangeDetectionManager.collectChangesSinceRevisions(DefaultChangeDetectionManager.java:220)
	at com.atlassian.bamboo.v2.trigger.DefaultChangeDetectionManager.collectAllChangesSinceLastBuild(DefaultChangeDetectionManager.java:164)
	at com.atlassian.bamboo.v2.trigger.DefaultChangeDetectionManager.collectAllChangesSinceLastBuild(DefaultChangeDetectionManager.java:190)
	at com.atlassian.bamboo.v2.trigger.ManualBuildDetectionAction.performDelayedChangeDetection(ManualBuildDetectionAction.java:154)
	at com.atlassian.bamboo.chains.ChainExecutionManagerImpl$1.getChainState(ChainExecutionManagerImpl.java:249)
	at com.atlassian.bamboo.chains.ChainExecutionManagerImpl.tryStartChainState(ChainExecutionManagerImpl.java:323)
	at com.atlassian.bamboo.chains.ChainExecutionManagerImpl.delayedStart(ChainExecutionManagerImpl.java:241)
	at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
	at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
	at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
	at java.lang.reflect.Method.invoke(Unknown Source)
	at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:343)
	at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:197)
	at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:163)
	at org.springframework.aop.interceptor.ExposeInvocationInterceptor.invoke(ExposeInvocationInterceptor.java:92)
	at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:185)
	at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:212)
	at com.sun.proxy.$Proxy235.delayedStart(Unknown Source)
	at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:206)
	at com.atlassian.bamboo.plan.PlanExecutionManagerImpl$1$1$1.lambda$call$0(PlanExecutionManagerImpl.java:375)
	at com.atlassian.bamboo.util.CacheAwareness.lambda$withValuesOlderThanTimestampReloaded$1(CacheAwareness.java:101)
	at com.atlassian.bamboo.util.CacheAwareness.withValuesOlderThanTimestampReloaded(CacheAwareness.java:126)
	at com.atlassian.bamboo.util.CacheAwareness.withValuesOlderThanTimestampReloaded(CacheAwareness.java:100)
	at com.atlassian.bamboo.util.CacheAwareness.withValuesOlderThanTimestampReloaded(CacheAwareness.java:151)
	at com.atlassian.bamboo.plan.PlanExecutionManagerImpl$1$1$1.call(PlanExecutionManagerImpl.java:374)
	at com.atlassian.bamboo.plan.PlanExecutionManagerImpl$1$1$1.call(PlanExecutionManagerImpl.java:367)
	at io.atlassian.util.concurrent.ManagedLocks$ManagedLockImpl.withLock(ManagedLocks.java:293)
	at com.atlassian.bamboo.plan.PlanExecutionLockServiceImpl.lock(PlanExecutionLockServiceImpl.java:75)
	at com.atlassian.bamboo.plan.PlanExecutionManagerImpl.doWithProcessLock(PlanExecutionManagerImpl.java:652)
	at com.atlassian.bamboo.plan.PlanExecutionManagerImpl.access$400(PlanExecutionManagerImpl.java:131)
	at com.atlassian.bamboo.plan.PlanExecutionManagerImpl$1$1.run(PlanExecutionManagerImpl.java:363)
	at com.atlassian.bamboo.utils.BambooRunnables$1.run(BambooRunnables.java:48)
	at com.atlassian.bamboo.security.ImpersonationHelper.runWith(ImpersonationHelper.java:26)
	at com.atlassian.bamboo.security.ImpersonationHelper.runWithSystemAuthority(ImpersonationHelper.java:17)
	at com.atlassian.bamboo.security.ImpersonationHelper$1.run(ImpersonationHelper.java:41)
	at java.lang.Thread.run(Unknown Source)
Caused by: com.tek42.perforce.PerforceException: Unable to parse output for change numbers.  Output: Path 'c:\Users\<user>\Bamboo\bin\<client_name>/depot/abc/xyz/...' is not under client's root 'C:\Perforce'.
	at com.tek42.perforce.parse.Changes.getChangeNumbers(Changes.java:130)
	at com.atlassian.bamboo.repository.perforce.PerforceManager.getLatestChangeNumber(PerforceManager.java:347)
	... 49 more
Caused by: java.lang.NumberFormatException: For input string: "'c:\Users\<user>\Bamboo\bin\<client_name>/depot/abc/xyz/...'"
	at java.lang.NumberFormatException.forInputString(Unknown Source)
	at java.lang.Integer.parseInt(Unknown Source)
	at java.lang.Integer.<init>(Unknown Source)
	at com.tek42.perforce.parse.Changes.getChangeNumbers(Changes.java:125)
	... 50 more
Sorry, this may be stupid, but being a newbie, I could not understand, from where it is picking such a  path -
Its an incorrect combination of where my bamboo is and the depot view I provided for repository.
and the reason for this error.
Please help me with this.
After some trials and understanding subsquent errors - I corrected -
Depot view to  - //client_name/abc/xyz...  (Removed /Depot)
and checked - Let Bamboo manage your workspace
