HI Team,
We have on-prem Bamboo server installed and it has a project with 200+ plans(Build+Deploy). Now we have to move this entire data from this Bamboo server (windows)to Bamboo(Linux) data center instance, everything including Logs, plans, ... etc information.
Please let me know the best way to transfer our data from Windows Bamboo instance to Linux Bamboo instance .
Already referred this link lhttps://confluence.atlassian.com/bamboo/exporting-data-for-backup-289277255.html , but still need your support.
Hello Dev G,
Welcome to Atlassian Community.
I think for your scenario you can refer this > https://confluence.atlassian.com/bamboo/cloning-a-bamboo-instance-289277407.html
There are two ways to do it, read the above page for detailed steps
1) Use Import and Export
2) Manually transfer the DB and Bamboo Home
Shashank Kumar
**please don't forget to Accept the answer if your query was answered**
Adding to the above, performing a full export/ import of a Bamboo instance can be very time consuming depending on the amount of artifacts and build logs you have. If your current instance has grown too large and export/ import does not work, you can still migrate your instance by using an alternative backup and restore strategy.
You can refer - https://confluence.atlassian.com/bamkb/how-to-migrate-a-bamboo-instance-with-a-large-number-of-artifacts-and-build-logs-1093015034.html
Thank you both,
Now , my requirement is, just need to migrate only 5 apps among 130, How to do it?
Thank you,
Dev G
Hello Dev G,
When you say Apps, do you mean External third party apps/Plugins which you have installed in your Bamboo system, please clarify.
Shashank Kumar
Hi @Anik Sengupta ,
No, our Bamboo applications with all Build and Deployment plans with data.
Thank you,
Dev G,
Hello Dev G,
You cannot move specific plans and Deployments easily. Import and Export will copy all the data from source to Destination.
If you want to move only specific plans and deployment, you should try Bamboo specs.https://confluence.atlassian.com/bamboo/bamboo-specs-894743906.html
Shashank Kumar
