Build Visual Basic 6 projects with Bamboo
Deleted user October 17, 2018
Hi Community,
Pretty much that, I would like to use Bamboo to build Visual Basic 6 apps, does any one did this?.
I haven't found any plugin or some other kind of solution to make this type of job on Bamboo.
Thanks a lot.
Gonchik Tsymzhitov
Hi!
Let's use Script task :)
This one will cover it :)
Gonchik Tsymzhitov
Deleted user February 9, 2019
Thanks for your reply Gonchik, but since Visual Basic 6 have the compiler on its own Visual Studio IDE how would you use script task to solve the compiling?. Sorry if my question is too dumb....
Thanks in advance!.
Gonchik Tsymzhitov
I hope, you need MSbuild
https://github.com/Microsoft/msbuild
https://docs.microsoft.com/en-us/visualstudio/msbuild/walkthrough-using-msbuild?view=vs-2017
or try to validate on command line build, then reuse it into Scripted Task.
Gonchik
