Expiry logic we have defined: anything older than 14 days can be removed, unless it is tagged “final” or “saveme”, with a minimum of 2 assets saved.
I have checked that some branches (e.g. OPL3-SBE8) are correctly deleting assets for builds older than 14 days, but it looks like OPL3-SBE3 and 4 are not working correctly.
Hi @Bharath,
It is not clear which Bamboo version you are running, but please keep in mind that Deployment release artifact expiry was added to Bamboo 5.7. Before that, only regular build artifacts could be deleted.
Can you please check if these artifacts that are not being deleted are really from regular builds, and not from deployments?
Felipe Kraemer
Hello Bharath,
It looks like support request which requires more investigation. Can you please create an issue at support.atlassian.com?
