We have several products that each require multiple VS solutions to be built to produce a product. A few years ago, we tried Bamboo and the issue was the Bamboo only supported a single solution. From what we have read, Bamboo only still supports a single solution configuration. Is there currently a work around for this and/or instructions on how to setup Bamboo to support multiple solutions for a single product?
I've used a build script to manage multiple solutions and/or projects, then just have Bamboo call it in a task. The build script does all the work and it's done in a single place.
I think you can achieve this simply using several Visual Studio tasks in sequence.
