Cobertura plugin building does not work
Ferenc Deak December 17, 2012
I am trying to follow the steps at https://bitbucket.org/i386/bamboo-cobertura-plugin/overview to build a cobertura plugin, but the process fails with the error message below.
Any hints on how to fix it?
solutions@bamboo:~/test/bamboo-cobertura-plugin$ mvn package -e
+ Error stacktraces are turned on.
[INFO] Scanning for projects...
Downloading: http://repo1.maven.org/maven2/com/atlassian/maven/plugins/maven-bamboo-plugin/4.0/maven-bamboo-plugin-4.0.pom
[INFO]
Unable to find resource 'com.atlassian.maven.plugins:maven-bamboo-plugin:pom:4.0' in repository central (http://repo1.maven.org/maven2)
Downloading:
[INFO]
[INFO]
[ERROR] BUILD ERROR
[INFO] ------------------------------------------------------------------------
[INFO] Error building POM (may not be this project's POM).
Project ID: com.atlassian.maven.plugins:maven-bamboo-plugin
Reason: POM 'com.atlassian.maven.plugins:maven-bamboo-plugin' not found in repository: Unable to download the artifact from any repository
from the specified remote repositories:
<br< a="">> for project com.atlassian.maven.plugins:maven-bamboo-plugin
[INFO] Trace
org.apache.maven.lifecycle.LifecycleExecutionException: Unable to build project for plugin 'com.atlassian.maven.plugins:maven-bamboo-plugin': POM 'com.atlassian.maven.plugins:maven-bamboo-plugin' not found in repository: Unable to download the artifact from any repository
com.atlassian.maven.plugins:maven-...
at org.apache.maven.lifecycle.DefaultLifecycleExecutor.loadPluginFully(DefaultLifecycleExecutor.java:1599)
at org.apache.maven.lifecycle.DefaultLifecycleExecutor.findArtifactTypeHandlersInPlugins(DefaultLifecycleExecutor.java:1468)
at org.apache.maven.lifecycle.DefaultLifecycleExecutor.findExtensions(DefaultLifecycleExecutor.java:222)
at org.apache.maven.lifecycle.Def...
at org.apache.maven.plugin.DefaultPluginManager.checkRequiredMavenVersion(DefaultPluginManager.java:293)
at org.apache.maven.plugin.DefaultPluginManager.verifyVersionedPlugin(DefaultPluginManager.java:205)
at org.apache.maven.plugin.DefaultPluginManager.verifyPlugin(DefaultPluginManager.java:184)
at org.apache.maven.plugin.DefaultPluginManager.loadPluginFully(DefaultP...
at org.apache.maven.project.DefaultMavenProjectBuilder.findModelFromRepository(DefaultMavenProjectBuilder.java:605)
at org.apache.maven.project.DefaultMavenProjectBuilder.buildFromRepository(DefaultMavenProjectBuilder.java:251)
at org.apache.maven.plugin.DefaultPluginManager.checkRequiredMavenVersion(DefaultPluginManager.java:277)
... 19 more
Caused by: org.apache.mave...
<br< a="">> at org.apache.maven.artifact.resolver.DefaultArtifactResolver.resolve(DefaultArtifactResolver.java:228)
at org.apache.maven.artifact.resolver.DefaultArtifactResolver.resolve(DefaultArtifactResolver.java:90)
at org.apache.maven.project.DefaultMavenProjectBuilder.findModelFromRepository(DefaultMavenProjectBuilder.java:558)
... 21 more
Caused by: org.apache.maven.wagon.ResourceDoesNotExistException: Unable to download the artifact...
PiotrA
December 17, 2012
Hello Ferenc,
Are you using Atlassian Plugin SDK bundled-in maven? My guess would be that you are using plain maven, which has no atlassian's public maven repositories configured - that's why it complain about missing artifacts... Could you try downloading Atlassian Plugin SDK and use 'atlas-mvn' from it instead of 'mvn' ?
Does it make sense?
Thank you, Yes, it fixed the error above ... Now I get the following:
[ERROR] BUILD FAILURE
[INFO] Compilation failure
/home/solutions/i386-bamboo-cobertura-plugin-2d35b690ebb5/src/main/java/com/atlassian/bamboo/plugins/cobertura/CoberturaResultWebItemCondition.java:[39,45] BUILD_KEY is not public in com.atlassian.bamboo.plugins.cobertura.tasks.CoberturaTask; cannot be accessed from outside package
/home/solutions/i386-bamboo-cobertura-plugin-2d35b690ebb5/src/main/java/com/atlassian/bamboo/plugins/cobertura/CoberturaResultWebItemCondition.java:[41,54] BUILD_NUMBER is not public in com.atlassian.bamboo.plugins.cobertura.tasks.CoberturaTask; cannot be accessed from outside package
/home/solutions/i386-bamboo-cobertura-plugin-2d35b690ebb5/src/main/java/com/atlassian/bamboo/plugins/cobertura/CoberturaResultWebItemCondition.java:[42,40] BUILD_NUMBER is not public in com.atlassian.bamboo.plugins.cobertura.tasks.CoberturaTask; cannot be accessed from outside package
/home/solutions/i386-bamboo-cobertura-plugin-2d35b690ebb5/src/main/java/com/atlassian/bamboo/plugins/cobertura/CoberturaBuildProcessorServer.java:[70,20] cannot find symbol
symbol : method getLastSuccessfulBuildSummary(java.lang.String)
location: interface com.atlassian.bamboo.resultsummary.BuildResultsSummaryManager
[INFO] For more information, run Maven with the -e switch
[INFO] Total time: 18 seconds
[INFO] Finished at: Tue Dec 18 12:30:46 CET 2012
[INFO] Final Memory: 94M/313M
and one more "annot be accessed from outside package
", I had to remove due to space limitation in this comment.
Nevermind the compile errors, I have bamboo 4.3 so the API seems a little bit incompatible. Here is the fix:
1. in ./src/main/java/com/atlassian/bamboo/plugins/cobertura/tasks/CoberturaTask.java make the symbols public
2. in ./src/main/java/com/atlassian/bamboo/plugins/cobertura/CoberturaBuildProcessorServer.java
replace the complained about line with:
PlanKey pk = PlanKeys.getPlanKey(buildContext.getPlanKey());
            BuildResultsSummary previousSummary = (com.atlassian.bamboo.resultsummary.BuildResultsSummary)buildResultsSummaryManager
                    .getLastSuccessfulResultSummary(pk);
It should work now.
PiotrA
December 17, 2012
Just curious - do you consider pushing back (via pull-request) your changes to the https://bitbucket.org/i386/bamboo-cobertura-plugin repository, so these changes can be shared among the community?
Not sure if that is feasible though...
I will try tomorrow :)
PiotrA
December 17, 2012
Ferenc Deak December 18, 2012
Cannot create a pull request, however I have created a mercurial bundle file. I will contact the previous developer to see what should I do with it.
