Configure Bamboo remote agent for deployment project
Arthur Gurov
August 13, 2014
I've started 2 remote agents for Bamboo and I can use them for build tasks. But the I need one of them to use it for deployment project. Currently I'm not able to specify dedicated remote agent for deployment because I don't see it in the list of available agents. I assume that my remote agents don't provide some capabilities.
Does anybody knows how I can configure remote agent to use it for deployment project?
Thanks in advice, Arthur.
ssetayeshfar
August 14, 2014
Hi Arthur,
Can you please open a support ticket at https://support.atlassian.comso we can get screenshots and more details to troubleshoot? Please use the same title as the one in this question so I can find it easier.
Thank you.
Best,
Sepideh
ssetayeshfar
August 13, 2014
Hello Arthur,
Do your remote agents not show up under Bamboo Administration - > Agents or when you select Agents from under the environment settings of your deployment project? Did you have builds running by your remote agenrs at the time you were trying to assign them to your deployment project?
Can you please refer to this page and let me know if it helps: https://confluence.atlassian.com/display/BAMBOO/Agents+for+deployment+environments
Thanks!
Best,
Sepideh
Arthur Gurov
August 14, 2014
Yep, I've faced exactly with this case. I know that agent is available - I can see it and use it for build, BUT I'm not able to select it for the deployment.
