Could not start executing Plan '<plan_key>' as the plan did not have any jobs to run
David Liem
May 13, 2016
I'm getting the following error with 2 of my Bamboo jobs.
    "Could not start executing Plan '<plan_key>' as the plan did not have any jobs to run"
In another post, I found that people are suggesting that it may be a permissions issue, but I have checked my user permission and all the permission in the repository where the plan runs, and everything seems to be fine.
Where can I look for more information on this error, or what can someone suggest I look in to to help resolve this issue?
Alexey Chystoprudov
May 13, 2016
This message means that all your jobs are disabled so nothing to run in current stage
David Liem
May 13, 2016
Thanks for your reply Alexey.  The plan is enabled, as far as I can tell from the Bamboo Plan UI.  I tried to toggle the enable as well.  There was still no affect.
Perhaps there is another place I can check for the enable setting, that is not properly getting updated?
Dmitry Medvedev
January 10, 2017
I have the same issue on 5.13.0.1:
  1. have a working branch plan
  2. plan was disabled for several minutes
  3. plan enabled again but I unable to run it with the same error
The issue solved for me after I disable/enable the job (I have only one) in plan (5.13.0.1).
