×Hi, We are using Nodejs with mongodb and redis dependencies. We are able to build nodejs image using dockerfile. Need to build an image with all these nodejs, mongodb and redis inside it.
We are using bitbucket and bamboo for building docker images. How can I achieve it??
I just want to pull the image and run it on environment.
Hi!
1. you can setup own docker registry and setup the task with script for pull and run it by Bamboo
2. You can use shared artifacts for build and use for those artifacts for run it by deployment plan
Gonchik Tsymzhitov
