Does -Dbamboo.delete.remote.agents.on.going.offline=true work?
Udo Hagemann [Decadis AG] May 8, 2024
How to configure Bamboo to automatically delete offline remote agents | Bamboo | Atlassian Documentation informs about a new system property to automatically remove agents entering offline state. On a test 9.6.2 instance with JVM_SUPPORT_RECOMMENDED_ARGS containing "-Dbamboo.delete.remote.agents.on.going.offline=true", offline agents are still present after hours.
Has anyone successfully configured this feature?
Kind regards!
Eduardo Alvarenga
May 8, 2024
Hello @Udo Hagemann [Decadis AG]
Thank you for the message. We are working internally to reproduce the issue and will get back to you soon.
Kind Regards,
Eduardo Alvarenga
Atlassian Support APAC
Eduardo Alvarenga
May 9, 2024
We detected that the latest Bamboo release was missing the "-Dbamboo.delete.remote.agents.on.going.offline=true" feature. However, we've rectified this and the feature should be included in the upcoming releases 9.6.3 and 10.0.0.
We apologize for any inconvenience caused.
Thank you and kind regards,
Eduardo Alvarenga
Like # people like this
