×I've just started to learn Bomboo. I'm trying to run job with very simply power shell script:
$a = findstr "def" main.py
if ($a) {return 1} else {return 0}
I got errors:
/u03/atlassian/bamboo-home/temp/TB-TPC-JOB-17-ScriptBuildTask-6890328877188670307.sh: line 1: =: command not found
/u03/atlassian/bamboo-home/temp/TB-TPC-JOB-17-ScriptBuildTask-6890328877188670307.sh: line 2: syntax error near unexpected token `{return'
/u03/atlassian/bamboo-home/temp/TB-TPC-JOB-17-ScriptBuildTask-6890328877188670307.sh: line 2: `if ($a) {return 1} else {return 0}'
What am I doing wrong?
Hi Nikita,
Did you select powershell as interpreter in the script task configuration?
And is your Windows agent running on Windows?
