I've configured a plan to use a network based Git Repository.
When I run the plan I get the following error.
Error encountered while triggering manual build: com.atlassian.bamboo.repository.RepositoryException: 'X: Web Group Technical DevGroup SOURCE CONTROL Git EchoWebServiceProcessor.git': java.net.UnknownHostException: 'G
Plan 'ESWP-ESWPDEV' did not start
I've also tried the full UNC servername Web Group Technical DevGroup SOURCE CONTROL Git EchoWebServiceProcessor.git
Where is the Git repository hosted? On a Windows file share? If you could post what the URL to the repository is here it will help me figure out whats wrong.
X:\Web Group\Technical\DevGroup\SOURCE CONTROL\Git\EchoWebServiceProcessor.git which maps to a file share \\serrvername\Web Group\Technical\DevGroup\SOURCE CONTROL\Git\EchoWebServiceProcessor.git
